andrewx19x Member 14 Member For: 16y 8m 20d Posted 15/02/10 10:31 PM Share Posted 15/02/10 10:31 PM (edited) Its happened a few times now the first time I had done a decent skid and after cruising for a bit the engine light come on for a few seconds then went away and done this twice and was still driving good a few days later the next time the engine light come on it stayed on and I was just driving normal this time and the car then seemed to be in limp mode and didnt want to rev and was mis firing massivly and when I switched motor it off I started it and was normal its done the limp mode thing to me twice now I have done a bit of work to it, it has been flashed and mods include 3" intake behind headlight front mount bov bigger injectors and is running a 10psi tune it still has factory exhaust centre muffler removed the car has not been retuned with these mods I am doing a full exhaust soon the cat was rattling but not anymore though so it might be blocked slightly I was thinking it might be the 02 sensor getting heated up due to the cat blockage and causing it to get into limp mode but any help would be greatly appreciated Edited 15/02/10 10:33 PM by andrewx19x Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/ Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 21y 1d Gender: Male Location: Brisbane Posted 16/02/10 12:03 AM Share Posted 16/02/10 12:03 AM So did you get it checked at all after the engine light came on the first few times?PS: Full stops are your friend Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-982241 Share on other sites More sharing options...
Panda Eyes flame magnet Gold Donating Members 5,674 Member For: 16y 11m 10d Gender: Male Location: adelaide hills- 'race air' central Posted 16/02/10 01:08 AM Share Posted 16/02/10 01:08 AM . . . . .. ... . .... .. .... .. .... ... . . . . Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-982262 Share on other sites More sharing options...
bluprinturbo Donating Members 605 Member For: 16y 11m 15d Gender: Male Location: brisbane Posted 16/02/10 10:32 AM Share Posted 16/02/10 10:32 AM exhaust or tune will probably be the culprits. does it do it with the stock tune? if so, then your cat may have collapsed. tuner time. Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-982497 Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 7m 21d Gender: Male Location: Southern Highlands NSW Posted 16/02/10 10:35 AM Share Posted 16/02/10 10:35 AM I think I saw a comma there somewhere Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-982499 Share on other sites More sharing options...
White Knight Donating Members 73 Member For: 15y 6m 6d Gender: Male Location: Sydney Posted 18/02/10 07:34 AM Share Posted 18/02/10 07:34 AM (edited) Yeah dude, punctuation makes it so much easier to read.Engine light, do you mean MIL? Just as a matter of prudence look at your oxygen sensor, this or it's wiring getting fried can cause this to happen (by some idiot failing to secure it in the workshop).Reason for edit:P.S. yes, that idle in the picture is not normal either. Edited 18/02/10 07:35 AM by White Knight Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-983239 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,331 Member For: 19y 7m 3d Gender: Male Location: Perth Posted 18/02/10 07:49 AM Share Posted 18/02/10 07:49 AM Its happened a few times now the first time I had done a decent skid and after cruising for a bit the engine light come on for a few seconds then went away and done this twice and was still driving good.A few days later the next time the engine light come on it stayed on and I was just driving normal this time and the car then seemed to be in limp mode and didnt want to rev and was mis firing massivly. When I switched motor it off I started it and was normal. Its done the limp mode thing to me twice now I have done a bit of work to it. It has been flashed and mods include 3" intake behind headlight front mount bov bigger injectors and is running a 10psi tune it still has factory exhaust centre muffler removed. The car has not been retuned with these mods.I am doing a full exhaust soon the cat was rattling but not anymore though so it might be blocked slightly. I was thinking it might be the 02 sensor getting heated up due to the cat blockage and causing it to get into limp mode but any help would be greatly appreciated Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-983247 Share on other sites More sharing options...
FOONIN Donating Members 678 Member For: 15y 11m 27d Gender: Male Location: CHCH NZ Posted 18/02/10 08:08 AM Share Posted 18/02/10 08:08 AM (edited) I nearly passed out reading all that, anyone read it all in one breath? as for problem..sounds serious.. Edited 18/02/10 08:08 AM by osonvs Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-983262 Share on other sites More sharing options...
Rhino1980 09JET Member 1,510 Member For: 15y 10m 7d Gender: Male Location: E. Maitland Posted 18/02/10 08:13 AM Share Posted 18/02/10 08:13 AM I now have epilepsy... If my engine warning light came on I'd be straight into the shop. Duh. Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-983268 Share on other sites More sharing options...
Gloo Member 403 Member For: 16y 11m 20d Gender: Male Location: Northern South Australia Posted 18/02/10 08:35 AM Share Posted 18/02/10 08:35 AM This used to happen in my ba.I found that it only ever happend if I bounced of the limiter a few times during traction issues, but as you said it sounded like it had droped a cylinder or 2, miss fired like crazy and struggled to rev. I took it to a workshop and they said it could be a few things.Number one idea was valve springs, they rekon I may have got some valve float while under WOT and put the car into limp mode. But I seemed to think it wasnt limp mode. It ran like sh*t, almost sounded like a milo tin hanging off the back of a soobie but very inconsistent tone.After a heavy run, they said the heat in the engine could be affecting the coils and causing some to not spark.Things to note, my engine light never come on, and my car was stock. Hope this info helps. Link to comment https://www.fordxr6turbo.com/forum/topic/66206-big-problems-ba-turbo/#findComment-983289 Share on other sites More sharing options...
