ITINT Member 16 Member For: 21y 7m 10d Posted 01/10/03 10:02 AM Share Posted 01/10/03 10:02 AM Twice in the last two weeks while accelarating My car started to miss and felt like it had dropped a cylinder or developed a nasty elec fault. Once I had pulled over switched it off and restarted everything was fine. Had to take it in to the dealer today to have the water pump O-ring seal replaced and asked them to check if any codes were up. They tell me it has codes up relating to wastegate/overboost? Not sure whether that was one code or not. Anyone else experienced a similar problem and does it sound like an overboost issue?My car has a Unichip and dealer says they cannot (or could be will not) reset the codes until I have the Uni removed. Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/ Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 22y 4d Gender: Male Posted 01/10/03 10:21 AM Share Posted 01/10/03 10:21 AM tell us more .... why aren't you going to APS to check the unichip?it may be slightly out, usually an easy fix.... B) who's the dealer and exactly did they say? Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54267 Share on other sites More sharing options...
GOLDIE My new toy Lifetime Members 5,344 Member For: 22y 8d Gender: Male Location: stanthorpe wine capital of qld. Posted 01/10/03 10:32 AM Share Posted 01/10/03 10:32 AM Sounds like the ceiling point for the boost has not been raised enough with the uni chip on.the problem is it is detecting over boost and it is shutting down the cyls.Ian Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54274 Share on other sites More sharing options...
camerooch Member 129 Member For: 21y 11m 8d Location: Melbourne Posted 01/10/03 12:46 PM Share Posted 01/10/03 12:46 PM Bring it in & we will take it off to Dynomotive to have it adjusted - You didint tell ME you had the UNICHIP ??!!!Thought you were going to WAIT for a while ??!!!CAM......!! Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54298 Share on other sites More sharing options...
F6 RAPID Formerly Turbo6 Donating Members 2,332 Member For: 22y 3m 22d Location: North Brisbane Posted 01/10/03 09:49 PM Share Posted 01/10/03 09:49 PM Sounds familiar................ Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54320 Share on other sites More sharing options...
ITINT Member 16 Member For: 21y 7m 10d Posted 02/10/03 02:24 AM Author Share Posted 02/10/03 02:24 AM I already had a booking arranged at APS for next week before the car went in to the dealer so will get them to check things out.Hopefully will just be an easy fix but I suppose I still need to resolve the code reset issue.What the Ford tech at Traralgon actually said was that he could not reset the code/s and even if he could he wouldn't unless the Unichip was removed?? Where are you located Cam? This might seem a stupid question but who are dynomotive? Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54357 Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 22y 4d Gender: Male Posted 02/10/03 02:41 AM Share Posted 02/10/03 02:41 AM ITINT said: Where are you located Cam? This might seem a stupid question but who are dynomotive? I think Cam may have you mixed up with someone else ... he's at KnoxFord , close to APS ... Dynamotive are a Bayswater Unichip outlet ....hope it all works out mate, don't agree with that Ford tech much ... let us know how you go cheersps ... I'm running a Unichip too and between APS/Dynomotive/KnoxFord the problem will be sorted out Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54363 Share on other sites More sharing options...
camerooch Member 129 Member For: 21y 11m 8d Location: Melbourne Posted 02/10/03 03:54 AM Share Posted 02/10/03 03:54 AM Sorry - ITINT - I did have you confused with someone else !!!!Sorry ROB - THE CUSTOMER IS ALWAYS RIGHT !!!!!Dynomotive are Enhancement & Dyno-tuning Experts & It is a PLEASURE to be associated with them.Would recommend them to anyone in MELBOURNE or AUSTRALIA WIDE if you want to TRAVEL !???!!! Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54382 Share on other sites More sharing options...
ITINT Member 16 Member For: 21y 7m 10d Posted 02/10/03 04:19 AM Author Share Posted 02/10/03 04:19 AM Thanks guys! :DAt least now I have somewhere to start....... and hopefully end!!!If it turns out to be a matter of some tweaking of the Unichip would there be any problem in resetting the codes?If not I might have to drop in and see you at Knox, Cam. Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54386 Share on other sites More sharing options...
FORDTECH Member 383 Member For: 21y 10m 30d Location: On the edge Posted 02/10/03 09:48 AM Share Posted 02/10/03 09:48 AM ITINT said: Twice in the last two weeks while accelarating My car started to miss and felt like it had dropped a cylinder or developed a nasty elec fault. Once I had pulled over switched it off and restarted everything was fine. Had to take it in to the dealer today to have the water pump O-ring seal replaced and asked them to check if any codes were up. They tell me it has codes up relating to wastegate/overboost? Not sure whether that was one code or not. Anyone else experienced a similar problem and does it sound like an overboost issue?My car has a Unichip and dealer says they cannot (or could be will not) reset the codes until I have the Uni removed. ITINT, The symptoms you describe are consistant with the "C" connector on the cars original PCM being unplugged(Have seen this on quite a few XR6T's). Just wondering where the UNICHIP actually plugs in to the electrics?From what I've read of the Unichip it actually fools the original PCM in to thinking everything is fine and therefore doesnt log any DTC's. Still trying to get my WDS onto one fitted with a Unichip to suss it out for myself. Link to comment https://www.fordxr6turbo.com/forum/topic/6614-overboost-problem/#findComment-54503 Share on other sites More sharing options...
