Alloy Header Tank
ENVYOSXR
  • Loves boost
  • Member For: 15y 8m 9d
Guys I have a coolant header tank to install, this is a basic question. On most alloy header tanks I notice that they have a outlet for a hose right below the cap. I see alot of engine bay pics with a hose connected to it but where does the other end go? I an guessing its just a drain point.
What do you guys do with this connector?
  • It's not a MKI!
  • Member For: 16y 7m 22d
I agree with the 'bling' side of things, but I believe they aren't as good as the standard tank as you can't see what sort of coolant level you have. Unless you're prepared to lift the cap every morning before you drive it, all it is is bling.
Just my 2c. :buttrock:
  • 4 weeks later...
  • Loves boost
Hey guys,
well finally got my header tank installed yesterday, was a piece of piss. All I did was disconnect the big hose and drain the plastic tank into a ice cream container so I didn't get water all over the place. Then removed the plastic one and bolted the alloy one in its place. Connected all the hoses backup and filled it back up with water, ran the car for for a bit while it was at operating temperature with the cap off.
Now on the way to work this morning I was thinking I didn't leave it idleing long enough as the water didnt flow out the cap of the header tank. I wouldn't imagine what I have done would cause a air lock in the system but how long should it be left at idle to get rid of air locks? Not to sure about bleeding the system on these cars, as my old xD had a bleed valve on the front of the head that let the air out.
Car drove perfectly this morning, was just a paranoid thought I had on the way to work.
any input would be appreciated
thanks guys.
