  • Replies 96
  • Member For: 19y 19d
Been playing with E85 in mine... these fuel rocks! Soaks up loads of psi and timing, soon as its available in a few more servos I'm going to use it as a daily mid 400 tune :)
  • Banned
  • Member For: 15y 10m 21d
how do you tune it though? to 70% or to the 85%? As the caltex bio fuel is rated at 70-85%. Id be scared to get a 85% full blend and have it tuned, then fill up from another servo and its only 70%. Wouldnt you risk to blow the motor etc?
Nah you dont tune it a percentage, you tune the same as you would for 98, targetting the same AFRs.
The main difference is E85 takes around 20-30% more fuel to make the same AFR... so for example, the max power you may get from 60lb dekas, you'll get from 80's, roughly speaking.
So for E85 you need to add in alot more fuel than you would for 98 to make the same power, but kicker is you can add ALOT more spark timing than you could for 98, and more timing makes more power... same deal as race fuels, toluene additives ect... oh and it'll take more boost befor it detonates.
So if your planning a strong 450wk tune, its a good idea to run around 1000cc injectors and 1200hp of fuel supply, so in my case two 044s.
I have a wideband 02 permenantly set up in the car so I can monitor AFRs as I drive.
With E85 the chances of breaking the motor are alot lower, for a given psi that is... I'm happy to feed my stock motor 22psi on 98, and 25psi on E85, maybe more but we're not at that level of "ballsyness" yet lol
The first thing you notice with E85 is the idle is silky smooth, the motor will rev and respond faster, power delivery is very very smooth and can be more linear.
We are constantly writing new tune files and trying them in the car on the street... not for max power,that's dyno only, but for midrange pull, throt response, idle , cruise ect.
I'm lucky enough to have two awesome tuners both with different approaches to tuning helping out with the tuning, one here and one way over west.
Right now we are just working more so on a strong 22psi tune for 98, then spend more time in finishing a polished E85, 25psi tune, but we've pretty much nutted out the do's and donts of E85, so will be able to get right into soon and hammer the motor :)
I still can't get over how much boost we could use on E85... same boost on 98 and I'd be on the phone to Brad by now lol
E85 = Good times!
I just re-read your post mate, yeah if it was tuned on 85, then you filled with 70 it would run richer, prob not by a huge amount... tuned on 70 and running 85 it would run lean, so I'd be tuning on 85, and then checking AFRs on 70 to see how rich its going... or have a second tune for 70.
So not quiet perfect yet...
  • ʎǝʞuoɯ ɹoıuǝs
  • Member For: 16y 5m 22d
hey Chris, stoich for e85 is 9.7:1 AFR, so I'm assuming if I don't recalibrate my wideband setup to suit, the gauge will show richer than using 98?
  • Member For: 15y 3m 5d
In the USA some of the pumps have seperate tanks & you can key in the % blend before you start filling up.
Wish we had it in WA, I might start lobbying my local MP :stirthepot:
  • Member For: 19y 11m
When using ethanol blends think lambda not AFR. If your E85 and 98ron tunes are calibrated for the exact same lambda then you will see the exact same AFR on your meter as what you would for your 98ron tune.
Edited by IH8TOADS
  • 2 weeks later...
  • Member For: 15y 10m 22d
  On 02/09/2010 at 1:48 PM, icer said:
if the pumps had a reading of the ethanol blend, on the pump, to let you know its 70 - 85% that would be great!
The Caltex is 70% winter blend for easier starting. I went off E85 for a a bit due to cold morning starts. Havn't tried the Caltex cocktail yet , but a mate has been using it and reckons no problems on cold moorning starts.
