Ba F6 Typhoon 2005 X2
navagator77
  • Toughest BA Turbo
  • Member For: 22y 2m 16d
The COBRA (and APS) kit were at their peak from 2003 to 2006.
The power level you are after is now not considered a big power upgrade.
There are many more component options around today to get your desired power levels and suit your requirements at a lower cost level.
Not sure why you’d go with BTA as a choice in Sydney. They would rank below Autotech, C&V and Tunehouse, who have far more experience in Sydney (and these are our forum advertisers that we support), and who have been tuning our Ford turbo cars for 7 years now.
IMO, you’re much better staying in your own state, for continuing support, and there are competent tuners in Qld.
IMO, for your requirements, tuning capability and good customer service are more important than which IC, exhaust, or plenum you may chose, for which you have many options, and a good workshop should be able to give you the advice you need. Even a full 4” exhaust is overkill for what you require, although quite often once we get used to a power level you tend to want more.
Don’t ignore suspension and brakes, and be more careful in the wet.
Brian
  • Member For: 15y 1m 15d
Thanks Guys for the reply...
BTA is some place in Sydney...
Personally I don't like the Cobra kit's that's why I wanted something different from the Boss...
I Have have everything sorted and will be tuned in Brisbane...
I'm getting
Large Inter cooler
Plenum
Battery relocation kit
Air intake of the turbo
The ABOVE from Plazmaman Kit
Race Valve Springs
60ld Siemens DEKA
3'5" Exhaust stainless
surge tank including 044 pump
Porting of Turbo and install of larger flapper
Flash Tuner
12lb actuator
If I have to spend a bit more...It's all good...
Installed and Tuned Right here in QLD
Edited by navagator77
  • Member For: 17y 10d
getting a tune done in another state when you have the option of getting a tune done in your own is absolutely ridiculous. I had the choice of 2 sydney tuners, one 20mins drive and the other 1 hour drive, with very little in price difference. I chose the cheaper one but cost me more in time due to having to go back to the tuner 4 times after that to fix up little issues with the tune. Each 1 hour drive I was cursing the tuner for being that much further away.
I couldnt imagine if he lived 1000ks away and had to fix and diagnose problems that far away
  • Member For: 15y 7m 5d
That is good in hiensight . But what if this happened with the turner that is 20 min away and u had to go back n forth when the 1 who is an hour away has a better turner u only have to get the job done once . But with what ever way u go I hope it go's good for u mate even to better turner make mistakes
