  • Member For: 19y 6m 28d
Hi all,
I had a weird symptom on my F6 in the last couple of days (warranty has just run out).
The parkers would not work and the ICC wouldn't dim and the dash lights would not work.
I traced this back to the column switch. These are designed quite poorly and a wire had broken inside. A quick solder and heat shrink tube and all was fixed, but it was a PITA to pull everything apart for this little wire.
Just thought I would let you know in case you come up against the same symptoms. The other wires look as though they are not far away from splitting also.
The car is only 3 years old.
Rob.
https://www.fordxr6turbo.com/forum/topic/65880-parkers-not-working/
  • Member For: 17y 3m 23d
Rob you have no luck with that car, good thing you`re handy with that sorta bidnez.
I reckon its cause you`ve not modded it..
Its just the best option, nothing soothes the temper like a really.. long.. skid.
I`m just sayin..
Edited by _Spin_
  • Senior Moron
  • Member For: 16y 1m 5d
Hey Rob,
had the same thing happen.....was told by Fraud its unrepairable and its gunna cost me around $500 to $600 to replace......went to a sparky that fixes cabs......$100 thank you :beerchug:
