  • Member For: 15y 4m 20d
As the topic says, just wondering if anyone knows how many BA and BF Typhoons where built, and also if the numbering was divided between them and the Tornados?
https://www.fordxr6turbo.com/forum/topic/65703-how-many-babf-f6s-were-built/
  • Force Fed Fords
  • Member For: 16y 8m 2d
On the wrong forums to ask this question mate... maybe you should look elsewhere to find this info... ;)
Edited by NFORCD
  • Member For: 16y 5m 7d
Someone on here probably knows, but they were a production car and didn't have a build limit (unless it's a special model like the R-Spec) so it will be heaps. Try doing a bit of googling you may find the answer on one of the other ford forums.
Cheers,
Ben
  • Member For: 16y 9m 8d
'05
Typhoon - 429
Tornado - 141
'06
Typhoon - 661
Tornado - 197
'07
Typhoon - 485
Tornado - 153
Force 6 - 59
Totals
Typhoon - 1575
Tornado - 491
Force 6 - 59
Accumulated Total for '05 - '07
F6 variants - 2125
Note: 2 things. I don't know if R-specs (of which there were 300) are included in these sales figures or not. I don't know how many, if any, BF MkII F6s were sold in '08. A few Force 6s were sold in '08. See below for '08 total sales figures for F6 variants.
'08
F6 Sedan - 537
F6 Utility - 154
Force 6 - 4
You could try ford forums, someone there will be able to give you an exact number, or you could try ringing FPV, don't know if they would help you or not though.
Edited by RapidF6
  • Member For: 16y 4m 20d
it does not bust that myth if its a BF MkI as they could go into the 700's seeing as they were not only built in 06, my BF MkII is No 28 and it was built late 06, I'm pretty sure they reset the build numbers for each model I.e BA MkI,BA MkII, BF MkI & BF MkII
  On 04/02/2010 at 6:32 AM, Robit28 said:
I have a 2006 F6 Typhoon in the 700's so that busts that myth!
FPV allocated number ranges for builds at different times in the model years. People were even able to pick which number they wanted within that range, meaning that not all allocated build numbers were used, I.e. there might be a Typhoon with the build number 650, and the next one might be 660.
It is a known fact that Force 6s were not numbered in numerical order also. They only sold 63 all up and it is known that the build numbers went beyond 63.
The numbers I posted are accurate. Someone made a call to FPV and got that info. If you don't believe me, then try the ford forums. They acquire and collate all the sales figures for each year and for each model. Lots of good info there and plenty of knowledgeable people also.
Edited by RapidF6
Correct! They reset the numbers for each model from BA MkII, to BF, to BF MkII.
