  • Replies 66
Posted Images
  • Member For: 19y 11m 14d
Was just looking at timing, I just can't run near that, even on 15psi. limited to 98 in wa. Whatever it is I hope you get it sorted soon.....it's looking too be a quick car :-)
  • Member For: 19y 10m 11d
And that's at 0.86 lambda too!
Good turbo setup huh? Less backpressure = more timing :)
Although in saying that.. that's my timing map from my previous turbo setup.. clearly that load point is 15psi at ~2.0 load. Although in saying that, my load 2.2 and 2.0 load points were the same timing values.
I guess the 100 octane United fuel helps a little too, And the fact I've got a aftermarket plenum. I've found some interesting things with the standard plenum I'll share with ya via Email if you wish.
  • Member For: 20y 2m 15d
Any substantial variation in fuel and octane makes quite a difference fella's.. I have never witnessed such an open discussion with the total absence of bullsh*t :beerchug:
Edited by SPIKO
Definately makes a difference in the Timing side of things, and the AFR.. However I've got a different issue all together.. lol
As long as you are logging Danny, which you are you will eliminate the gremlins quick smart, this is an accurate/solid process...
Edited by SPIKO
  • Legendary member!!
  • Member For: 18y 5m
Come on Danny,
you cant do that - gotta share it with us bud...
Should start saving for the aftermarket plenum huh??
Short answer. Yes.. STD plenum hurts top end power. I've seen increases of the likes of 40rwkw by swapping to a plenum, and retuning.
I think the std plenum really is good for 360rwkw or so.. Not saying this is the Max power you'll get out of it, But I'd say that's about the point where the plenum starts restricting airflow
  • Member For: 16y 5m 2d
Thanks heaps for this thread Danny,
I think ive read it 4 or 5 times now as im getting the Process West fuel rail very soon and have decided to pull the 60lb's out and go with the ID 1000's.
Couple of quick questions.
The standard plenum you mention above, im guessing is the B series? Anything to note with the FG's? Be happy to give you my email if you'd rather not reply on here.
Any issues if fitting a bigger fuel reg if needed?
I gained exactly 50rwkw's with a plenum....I did beef up the actuator though and added about 1.5 psi at the top end. BUT I took something like 8 degrees out of the borderline knock table!!
Edited by IH8TOADS
