berzerker Donating Members 767 Member For: 17y 3m 18d Gender: Male Location: Brisbane Posted 31/01/10 08:00 AM Share Posted 31/01/10 08:00 AM Had my Plazmaman cold side piping on for a few weeks now, just wondering if this is the correct setup, or whether it should be blocked, and if so, is there a different sound, or is it best to leave it as it is now. If I block it up, is that whats referred to as plumb back?ORShould I purchase a bigger BOV than this? Am running 310rwkw@15psiCheers all!Tim Link to comment Share on other sites More sharing options...
Molloy Member 216 Member For: 17y 1m 20d Gender: Male Location: Taree Posted 31/01/10 08:29 AM Share Posted 31/01/10 08:29 AM That should be fine, Id get a better one though, stock units are fair weak Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 5m 21d Gender: Male Location: Miranda Posted 31/01/10 10:55 AM Share Posted 31/01/10 10:55 AM plumb it back to the air intake like the process west and original factory setuip Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 5m 21d Gender: Male Location: Miranda Posted 31/01/10 10:57 AM Share Posted 31/01/10 10:57 AM Would you plumb it back to the air intake like the factory and Process west systems?whats wrong with the BOV supplied? where is the weakness? Link to comment Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 17y 3m 18d Gender: Male Location: Brisbane Posted 01/02/10 08:48 AM Author Share Posted 01/02/10 08:48 AM Ok cool thanks guys, but what will it sound like if I block up the hole? will it decrease/increase performance?And what exactly does plumb back mean? Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 5m 21d Gender: Male Location: Miranda Posted 01/02/10 09:50 AM Share Posted 01/02/10 09:50 AM Mate it looks like you have the BOV big hose on the wrong way, the pressure side looks like its connected on the vent side.I dont know how the internals of the valve works but the little hose is a vacume hose that releases the pressure when you back off the throttle. where the air comes out looks like its attached to the pressure sideplumb back means run a hose back from the outlet valve to the air intake so the air goes back to the turboif you block the valve off there is no point in having one... there are a few threads here suggesting that you can block it off but it seems a uneducated move IMO Link to comment Share on other sites More sharing options...
berzerker Donating Members 767 Member For: 17y 3m 18d Gender: Male Location: Brisbane Posted 01/02/10 11:08 AM Author Share Posted 01/02/10 11:08 AM Mate it looks like you have the BOV big hose on the wrong way, the pressure side looks like its connected on the vent side.I dont really know, Can anyone else confirm this from the pics?plumb back means run a hose back from the outlet valve to the air intake so the air goes back to the turboYou mean from the end that's currently open on my setup to the hose on the CAI, right?if you block the valve off there is no point in having one... there are a few threads here suggesting that you can block it off but it seems a uneducated move IMOWont be doing it then, will either leave it or plumb it back to the CAI, if I understood what you said before.. Link to comment Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 29d Gender: Male Location: Melbourne,S.E Posted 01/02/10 12:04 PM Share Posted 01/02/10 12:04 PM the 25mm outlet on the side of the BOV should be connected to the cooler pipe. and the other outlet should bevented out. the air should be coming into the side of the BOV. silly ford design. Link to comment Share on other sites More sharing options...
ravenhard Donating Members 1,517 Member For: 17y 1m 5d Gender: Male Location: Blacktown! Posted 01/02/10 12:13 PM Share Posted 01/02/10 12:13 PM silly ford design.its not often I stick up for Ford, but its actually a silly Bosch design. Not ford. They have been using this BOV for years and use it on other cars such as VW's and Audi's Link to comment Share on other sites More sharing options...
ROLMDL role model Member 1,111 Member For: 19y 29d Gender: Male Location: Melbourne,S.E Posted 01/02/10 12:56 PM Share Posted 01/02/10 12:56 PM that's true my bad. Link to comment Share on other sites More sharing options...
