Rockatansky Member 591 Member For: 15y 2m 5d Gender: Male Posted 07/05/14 09:43 AM Share Posted 07/05/14 09:43 AM (edited) So I looked underneath today,Drain plug's as tight as, wiped away the excess oil and will monitor the leak. Still only one drop overnight.Could it be the diff cover seal itself? Edited 07/05/14 09:45 AM by Rockatansky Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/3/#findComment-1470081 Share on other sites More sharing options...
Tim Member 142 Member For: 16y 11m 4d Posted 19/04/15 07:10 AM Share Posted 19/04/15 07:10 AM Did mine today. Just drove the rear wheels on to some bricks and it gave just enough room to get it done. 10mm Allen key (for FG) filler bolt was bloody tight. Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/3/#findComment-1540494 Share on other sites More sharing options...
Jakeychanxr6turbs New Member 10 Member For: 7y 2m 5d Gender: Male Location: Emu Plains Posted 14/04/18 05:20 AM Share Posted 14/04/18 05:20 AM You are the man Spin , awesome instructions , filler nut was a 30 for me , thanks man ?? Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/3/#findComment-1655593 Share on other sites More sharing options...
masda74 To Loud Gold Donating Members 4,112 Member For: 13y 6m 16d Gender: Male Location: WA, Perth Posted 17/04/18 03:20 AM Share Posted 17/04/18 03:20 AM Solid I am not sure if any of the original members in this thread are still around. I just did mine on Friday. Seems that there are different plugs out there for the diff. My FG needed an allen key to get the plug out of the fill hole. The bottom sump plug for the diff is a bolt. Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/3/#findComment-1655731 Share on other sites More sharing options...
El Andrew Gold Donating Members 2,039 Member For: 10y 1m 24d Gender: Male Location: Canberra ACT Posted 21/04/20 04:32 AM Share Posted 21/04/20 04:32 AM This thread was useful - just did mine. 2010 FG had the 10mm hex filler plug. Allen key was fouling on the sway bar (I've got a big Whiteline unit so might be different if stock). I put the Allen key in horizontally and they used a 10mm spanner on the Allen key shaft to undo the plug.Stuff that came out looked pretty ordinary compared to the new stuff! Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/3/#findComment-1693983 Share on other sites More sharing options...
