My_XR6_Turbo Member 282 Member For: 20y 9m 30d Posted 09/05/09 10:29 AM Share Posted 09/05/09 10:29 AM I want to change the oil in my Diff. I was looking around the forum and found the topic about the diff on the ute. Can someone tell me if the pic of the diff for the ute is the same as the sedan for filling and emptying. If not has someone got a pic? Can it be done just using a jack?http://www.fordxr6turbo.com/forum/index.ph...540&hl=diffThanks, 1 Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/ Share on other sites More sharing options...
ENVYOSXR Loves boost Donating Members 266 Member For: 16y Gender: Male Location: VIC Posted 01/07/09 08:09 AM Share Posted 01/07/09 08:09 AM I am after the same information, wanting to change the diff fluid the a BA MKII sedan any pointers or guides? I heard there is a rubber gromit in the spare wheel well on the MKII to fill it up from, is this correct? thanks guys 1 Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-899377 Share on other sites More sharing options...
JBJARROD Member 12 Member For: 16y 2m 3d Posted 07/07/09 09:22 AM Share Posted 07/07/09 09:22 AM (edited) Ok, Is fairly easy job, I used a 1 litre bottle of diff oil in a plastic hand pump cyclinder (I used Nulon stuff bout 60 bucks for 2l)I had to use a few extensions and a large think it was 22mm socket (but not too sure) to undo the large inlet bolt at the back of the diff. There isnt very much room to do it in the sedans and I have a BF MK1 and no easy access hole to fill it up :(. I just jacked the car up and did it with a hand pump.Should take about 1 hr to but I let it drain out overnight then refilled it the next morning.Oh I forgot to empty the oil you have to undo the bottom diff bolt to let the oil come out. Edited 19/01/11 09:16 AM by RHR No need to quote above post. USE FAST REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-902768 Share on other sites More sharing options...
_Spin_ Donating Members 695 Member For: 17y 3m 27d Posted 26/01/10 07:10 AM Share Posted 26/01/10 07:10 AM (edited) Okay I`ve wanted to do this for a while. I had to get my tools out to fix a fuel leak in Bullpitts car so I thought why not?I used: An inch and three sixteenths ( 1 - 3/16 ) socket, half inch drive ratchet for the filler plug.A 15 mm Ring - open ender for the drain boltA suction pump to put the oil in ( see pics) I put the car up on jack stands, it has SSL`s and even my spoofy lowered car ramps won`t go under the rear on flat ground. Next time I`ll do it on the slope of the driveway and get the diff more level. On the stands it wasn`t too bad but a smidge of oil stays in the diff. No biggie.First pic shows what you`re up against with sedan versus Ute.. That barge arse IRS cradle. Access is restricted somewhat.Next pic shows you the Filler plug, mine was`nt real tight at all eh. As stated it was 1-3/16`s socket.The drain bolt is obviously at the bottom of the diff rear hat, that's the alloy cover, and it seems to be the only one that's 15mm, the others are smaller. Whip that out and have your receptcle handy. It`s only 2 litres or so so it doesn`t roar out.Go check the forums for some internet argueing while it drips out for a while, beverage or sanga would be optional.Here`s what I bought for the job. The oil was.. I forget how much you`ll have your brand you`ll wanna use. The suction pump is a famous Toledo ( says so on the box eh ) brand and cost me the princely sum of 29.99 at Supercheap.Now.. I poured what came out into a milk bottle, I put that amount back in with the suction pump, it didn`t run out the filler hole but I inserted my lil finger ( settle ) and it was right there. If you wanna put a tad more in and have it run out by all means be my guest. Here`s what came out, it wasn`t too black, it`s just the residue of oil changes past and grass and sh!t from the drain pan sitting behind the shed.Put every thing back on the way it was when you removed it, including the diff tag. One day in 40 years some hapless schmuck will be restoring you car and thank his lucky stars its there. Maybe. Edited 26/01/10 09:49 AM by tab Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-974867 Share on other sites More sharing options...
ENVYOSXR Loves boost Donating Members 266 Member For: 16y Gender: Male Location: VIC Posted 29/01/10 02:54 AM Share Posted 29/01/10 02:54 AM Gee do you clean under your car oftern or is all that stuff new underthere? Looks good but! Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-975949 Share on other sites More sharing options...
82CNT Member 363 Member For: 16y 6m Gender: Male Location: Brisbane North Posted 29/01/10 03:28 AM Share Posted 29/01/10 03:28 AM Good write up bud. Yeah it does look bloody clean under there. Mine looks nothing like that! Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-975963 Share on other sites More sharing options...
kane_tools Donating Members 47 Member For: 15y 7m 1d Gender: Male Location: Coniston/Wollongong Posted 26/05/10 05:30 AM Share Posted 26/05/10 05:30 AM (edited) Just done this job and the filler plug is actually 29mm.It will make a lot more sense than trying to find a 1 3/16 in socket at Bunnings!!! (this is not a common size socket) Edited 26/05/10 05:34 AM by kane_tools Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-1010755 Share on other sites More sharing options...
4DZILR Donating Members 713 Member For: 15y 3m 27d Gender: Male Location: Sydney - Brighton Le Sands Posted 24/10/10 10:09 PM Share Posted 24/10/10 10:09 PM My diff is leaking... Does anybody know if diffs need a new gasket? or is it just a matter of remove, clean, cykaflex?? Also - As im in need of my diff bushes changed, im guessing its best to get it all done at once?? Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-1050237 Share on other sites More sharing options...
XF Falcon <put funny sh*t here> Member 3,365 Member For: 18y 6m 24d Gender: Male Location: Perth, NOR Posted 03/01/11 02:38 PM Share Posted 03/01/11 02:38 PM Tried this today, excellent idea!! I used to use a suction pump and do it in like 10 goes to fill it up.now I just got a fat clear rubber hose, fed it through the rear driver side rim, through the suspension and straight into the filler hole.then I just held up the tube from outside the car, and poured the bottles in. the castrol SAF-XA bottle has the nozzle which fit tightly into the tube, and when I pushed the bottle it forced it down the tube. to empty the tube for removal, I just squeezed the empty bottle into the tube and the air pressure fed it all through the tube into the diff.much easier idea, thanks for the tip! Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-1068822 Share on other sites More sharing options...
YOB POM Member 140 Member For: 19y 11m 27d Gender: Male Location: Jimboomba Qld Posted 18/01/11 10:11 AM Share Posted 18/01/11 10:11 AM Fill plug on BA sedans is 29mm.John Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/#findComment-1073506 Share on other sites More sharing options...
