YOB POM Member 140 Member For: 19y 11m 29d Gender: Male Location: Jimboomba Qld Posted 19/01/11 06:40 AM Share Posted 19/01/11 06:40 AM Update I believe it's not 29mm it must be AF as a 30mm will remove it but is pretty sloppy and 29 wont go on Mods if you just want to delete my cock up, delete away. Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1073764 Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 4m 3d Posted 19/01/11 09:01 AM Share Posted 19/01/11 09:01 AM Jack the car up with the front a little higher than the back,to get all the oil out of the diff. Bottom bolt of diff cover is the drain bolt and large plug on drivers side of diff housing is the filler hole. Make sure the car is level when you fill it with new oil. Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1073829 Share on other sites More sharing options...
vxr50t Member 134 Member For: 12y 1m 23d Posted 24/08/13 07:48 AM Share Posted 24/08/13 07:48 AM (edited) I know this thread is old but thought I'd throw it up just for reference for the newer FG owners. I just changed my diff oil at 36k on my 2010 FG sedan and the filler hole is a 10mm hex, drain is still 15mm. Process is still the same, I used new penrite gear oil and threw in a whole tube of nulon diff treatment and blue loctite on the plug threads. Difference is amazing, sounded like I had rocks in my diff prior to oil change and now its so quiet. Will definitely do it more often Edited 24/08/13 07:50 AM by vxr50t Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1418441 Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 17y 25d Gender: Male Location: Greenvale, Victoria Posted 21/01/14 05:21 AM Share Posted 21/01/14 05:21 AM Don't use a ring spanner to undo the drain plug on a BF it gets stuck and ya cant get it out. That's probably why it said earlier to use an open end spanner. Ahhh to hell with convention. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1451264 Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 17y 25d Gender: Male Location: Greenvale, Victoria Posted 22/01/14 03:02 AM Share Posted 22/01/14 03:02 AM I performed this oil change today and it was as simple as explained and certainly as easy as an engine oil change if not easier. A suction pump is the go and a 30mm socket for the filler plug is certainly adequate. A tip on another forum is to make sure you can undo the filler plug before you drain. No sense draining the diff if you can't fill it.It is amazing how filthy the fluid is that comes out but then I don't think its ever been changed on my car. Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1451426 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 10d Gender: Male Location: Probably above atmospheric pressure Posted 22/01/14 05:46 AM Share Posted 22/01/14 05:46 AM How many kms dude? Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1451446 Share on other sites More sharing options...
arronm Dropping a turd Gold Donating Members 9,520 Member For: 17y 7m 7d Gender: Male Location: Perth Posted 22/01/14 06:57 AM Share Posted 22/01/14 06:57 AM 2 Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1451463 Share on other sites More sharing options...
Breeze_xr Bronze Donating Members 168 Member For: 13y 2m 29d Gender: Male Location: Newcastle Posted 22/01/14 09:17 AM Share Posted 22/01/14 09:17 AM I have that exact pump and it worked great when I changed the fluid in my diff Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1451483 Share on other sites More sharing options...
Rockatansky Member 591 Member For: 15y 1m 23d Gender: Male Posted 23/04/14 10:10 AM Share Posted 23/04/14 10:10 AM Yeah mine's leaking too... only a drop over night... should I be worried? Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1467169 Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 6m 10d Gender: Male Location: Probably above atmospheric pressure Posted 24/04/14 05:11 AM Share Posted 24/04/14 05:11 AM YesTime to put in a new True Trachahaha Link to comment https://www.fordxr6turbo.com/forum/topic/65487-sedan-diff-oil-change/page/2/#findComment-1467317 Share on other sites More sharing options...
