GreenXR6T Donating Members 630 Member For: 19y 8m 5d Gender: Male Location: NSW Posted 25/01/10 11:22 PM Share Posted 25/01/10 11:22 PM Howdy all,I have a question for those who have installed valve springs on their cars.My car had the good ol p!ssweak Nizpro valve springs which I had to change cause they were floating at high boost.When I put the Atomic springs in I noticed there was a washer or shim on the valve guide seal under the spring, but according to the workshop manual it doesn't show this washer (it's a N/A head though). It shows the spring seated on top of the seal.I wasn't sure if the turbo needed these or if Nizpro used them to increase the tension of their ones.I have the engine out now (oil pump) and have noticed the cams and rockers seem to have more wear on them since I installed the Atomic springs. I thought maybe the shims added extra tension and caused more wear?Any help is appreciatedRob Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/ Share on other sites More sharing options...
Guest EGOXRT Guests Posted 26/01/10 01:38 AM Share Posted 26/01/10 01:38 AM (edited) They would be Nizpro fitted/supplied to lift seat pressure, piss them off. Edited 26/01/10 01:38 AM by EGOXRT Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-974798 Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 8m 5d Gender: Male Location: NSW Posted 26/01/10 04:49 AM Author Share Posted 26/01/10 04:49 AM Are you sure? Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-974844 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 18d Gender: Male Location: Earth Posted 26/01/10 05:42 AM Share Posted 26/01/10 05:42 AM I'd reckon they are there to stop the steel valve springs eating away at the aluminium head. Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-974853 Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 8m 5d Gender: Male Location: NSW Posted 26/01/10 10:11 AM Author Share Posted 26/01/10 10:11 AM I thought that too but the valve guide seal has a steel lip on it that neatly fits under the spring to stop it seating on the head. Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-974936 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 10m 18d Gender: Male Location: Earth Posted 26/01/10 12:07 PM Share Posted 26/01/10 12:07 PM If that's the case then I'd say they are shims that have been used to get the correct seated spring pressures. Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-974996 Share on other sites More sharing options...
Adam Here since the start... Lifetime Members 10,282 Member For: 22y 12d Gender: Male Location: Victoria Posted 27/01/10 06:20 AM Share Posted 27/01/10 06:20 AM Phone them and ask. Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-975145 Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 8m 5d Gender: Male Location: NSW Posted 27/01/10 01:17 PM Author Share Posted 27/01/10 01:17 PM I might do that and phone Brad from Atomic. He's a champion to deal with, just like Kevin from Process West. Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-975358 Share on other sites More sharing options...
GreenXR6T Donating Members 630 Member For: 19y 8m 5d Gender: Male Location: NSW Posted 28/01/10 01:59 AM Author Share Posted 28/01/10 01:59 AM Thanks for the input fella's.Brad says that they seat on the valve spring seal, so out they go...They were another Nizpro cheap ass fix by the look of it. Link to comment https://www.fordxr6turbo.com/forum/topic/65473-valve-spring-help/#findComment-975496 Share on other sites More sharing options...
