gazza04xr6t Member 4 Member For: 16y 9m 15d Posted 25/01/10 12:25 PM Share Posted 25/01/10 12:25 PM any one had front brake pad rattle on ba xr6 ? Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/ Share on other sites More sharing options...
Benji_vs Donating Members 403 Member For: 17y 1m 3d Gender: Male Location: East Suburbs Melbourne Posted 25/01/10 12:43 PM Share Posted 25/01/10 12:43 PM Bit more info mate.What sort of car is it? Does it happen over all bumps? At what speed? It may not even be the brakes Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974692 Share on other sites More sharing options...
RSK Member 340 Member For: 17y 8m 28d Gender: Male Posted 25/01/10 01:31 PM Share Posted 25/01/10 01:31 PM Mine always have, and is evident over really small bumps at low speed, under/around 30, but mostly over a road that's made out of bricks/pavers. As soon as you ever so lightly apply the brake (not enough to actually slow the car down) it disappears. I believe it's the brake pad rattling in the caliper, and have heard a few people say there's a clamp to keep the caliper in place. I've taken it to a forum sponsor and they said a brake pad change will fix it, which it did, but it came back within a few thousand km's. Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974701 Share on other sites More sharing options...
Grug Member 1,318 Member For: 16y 10m 12d Posted 25/01/10 09:07 PM Share Posted 25/01/10 09:07 PM I notice a rattle coming from the front of the car somewhere, sounds like someones jingling bells or something.. Guess that's what it is? Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974734 Share on other sites More sharing options...
turbomonkey Banned 9 Member For: 15y 8m 8d Gender: Male Posted 25/01/10 10:59 PM Share Posted 25/01/10 10:59 PM try a little silicone between pads and caliperto keep it from moving or buy a product call antisquellit in a red bottle about $20 Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974756 Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 4m 23d Gender: Male Location: Christchurch, New Zealand Posted 26/01/10 12:55 AM Share Posted 26/01/10 12:55 AM I had this happen on my motorbike and what was happening is the caliper pistons on one side weren't self adjusting so therefore as the pad wore down it had a gap instead of always just touching the disc. The way to fix it was take the caliper off pull it apart clean everything some new o-rings and make sure there were no burrs on the pistons themselves as that could cause an issue as well. By the sounds of it you are having the same issue. Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974787 Share on other sites More sharing options...
gazza04xr6t Member 4 Member For: 16y 9m 15d Posted 26/01/10 05:25 AM Author Share Posted 26/01/10 05:25 AM thanks for the replys.my 04 xr6t started makeing a rattleing noise at the front . was easy to find just thump the front tyre , you can stop the noise bypushing on the brake pads . mine started about 75000 kms . have heard it is a common thing / makes a good car sound like rubbish . Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974851 Share on other sites More sharing options...
Smoke them tyres Member 557 Member For: 17y 5m 19d Gender: Male Location: Brisbane Posted 26/01/10 06:23 AM Share Posted 26/01/10 06:23 AM Have you recently changed your shock absorbers? Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974859 Share on other sites More sharing options...
NitroXR6T Member 28 Member For: 16y 11m 30d Posted 26/01/10 11:41 AM Share Posted 26/01/10 11:41 AM seems like a factory fitted thing! 3200kms and ive got it too. (Front left) Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974989 Share on other sites More sharing options...
gazza04xr6t Member 4 Member For: 16y 9m 15d Posted 26/01/10 12:03 PM Author Share Posted 26/01/10 12:03 PM nothing has been changed, the car is stock standard. someone else said to peen over the edges of the pads to tighten then up in the caliper ? might try some factory/bendix pads and see wot happens. Link to comment https://www.fordxr6turbo.com/forum/topic/65467-front-brake-pad-rattle-noise-over-small-bumpsanyone-heard-of-fix/#findComment-974995 Share on other sites More sharing options...
