Starter Motor Removal
Strike_Lightning
  • Strike_Lightning
  • Member For: 18y 8m 11d
hi guys, I have a problem with my starter motor and I did some searching but can't seem to find any advice on how to remove it, I'm sure it would of been talked about before, can someone point me in the right direction?
cheers
  • Strike_Lightning
hi Adam
the solenoid is clicking in and out but starter motor not turning, so I thought I would remove it and check it out on the bench, if its any thing like my young blokes Late model camira ute it will be a mission to remove. so I thought I would ask before I get underneath and check it out.
dg
  • Sucker
  • Moderating Team
  • Member For: 20y 7m 9d
Perhaps a silly question and a bit of a cliche response, but it's not a dud battery is it?
As far as the actual answer to your question though I got NFI....can't imagine it being simple :roflmbo:
  • TRAITOR
  • Member For: 22y 1m 15d
Very simple, just fiddly. Get under the car, two bolts holding the starter. Bottom bolt is easy, top bolt is a fiddly *beep*. Out it comes. Oh, take the wiring leads off it too.
  • Here since the start...
  • Member For: 21y 7m 8d
Check that the wiring isn't loose. I've seen the nut on the starter come loose and cause this.
Flat battery would've been my guess too.
You could bridge it in the car, saves taking it out.
If you do take it out remove the negative lead from the battery first.
