PerthPete Member 10 Member For: 18y 8m 10d Gender: Male Location: Perth Posted 20/01/10 08:48 AM Share Posted 20/01/10 08:48 AM Hello all, I wonder if someone can advise me please. I have a 3yr old F6 Typhoon, over the last few months I have been getting an odd thump under the front left hand side, sounds very much like a rock hitting the underside of the vehicle, which is what I thought it was at first until I started to hear it when the car was stationary at the lights and last time stationary in a car park. The odd thing is that it only happens every once in a while and may take up to 100ks before it happens again and only one thump. I know this sounds weird and I dont want to take it to the Ford service without some clue because unless they hear it I doubt they will have any idea and will want to take it for extensive testing and charge me big bucks to do it. I just wondered if the collective mechanical knowledge on this site might have a clue. Any advice would be appreciated.Cheers, Pete Link to comment Share on other sites More sharing options...
_Spin_ Donating Members 695 Member For: 16y 11m 24d Posted 20/01/10 09:01 AM Share Posted 20/01/10 09:01 AM Open your bonnet, sit behind the wheel and start the car, with your foot on the brake stall the car up in first.. If the motor tries to fold over the drivers side front guard you need a new engine mount. Link to comment Share on other sites More sharing options...
PerthPete Member 10 Member For: 18y 8m 10d Gender: Male Location: Perth Posted 21/01/10 07:42 AM Author Share Posted 21/01/10 07:42 AM (edited) Many thanks Spin - much appreciated. Edited 21/01/10 07:42 AM by PerthPete Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 1d Gender: Male Location: central coast Posted 21/01/10 07:45 AM Share Posted 21/01/10 07:45 AM That or the little D rubber on the front sway bar is stuffed ,the ones that mount the bar to the front frame. Link to comment Share on other sites More sharing options...
_Spin_ Donating Members 695 Member For: 16y 11m 24d Posted 21/01/10 07:48 AM Share Posted 21/01/10 07:48 AM Let us know how you go and what it ends up being.. Link to comment Share on other sites More sharing options...
PerthPete Member 10 Member For: 18y 8m 10d Gender: Male Location: Perth Posted 04/02/10 12:35 AM Author Share Posted 04/02/10 12:35 AM (edited) It was investigated by Titan Ford and they found it to be a relief valve (or similar)which is set close to the left hand side body and when it dischargesit can hit the inside of the wheel arch - this valve has been moved slightly and a dampening material inserted between the valve and the side of the engine compartment. Thanks for your interest and advice. Much appreciated. Edited 04/02/10 12:41 AM by PerthPete Link to comment Share on other sites More sharing options...
_Spin_ Donating Members 695 Member For: 16y 11m 24d Posted 04/02/10 08:36 AM Share Posted 04/02/10 08:36 AM Kewl. Link to comment Share on other sites More sharing options...
PerthPete Member 10 Member For: 18y 8m 10d Gender: Male Location: Perth Posted 05/02/10 04:34 AM Author Share Posted 05/02/10 04:34 AM (edited) I meant a purge valve - in any case - it hasnt worked...got the thmp again today..... Edited 05/02/10 04:37 AM by PerthPete Link to comment Share on other sites More sharing options...
alchemist Inactive Members 1 Member For: 14y 11m 23d Posted 06/02/10 03:56 PM Share Posted 06/02/10 03:56 PM Pete, try safely jacking the vehicle up off the ground, climbing underneath and attempt to wobble everything under your vehicle around the front. Link to comment Share on other sites More sharing options...
