Engine Starting Problem
Alan_86
  • Inactive Members
  • Member For: 15y 17d
Hi I have a XR6 BF 2005 Sedan 4.0L 6 speed with a strange problem.
When the car is cold the engines starts fine but if I would to drive for over a certain time period and the car engine is at high temp , and the car has been turned off it will have some problem starting again until its cooled down.
Need help in getting it fixed
Regards
Alan
  • BOOST
  • Moderating Team
  • Member For: 21y 4m 29d
You might wanna check your coolant and have a mechanic change the thermostat. Sounds like its running hot and I could be putting the car into limp mode
  • Mmmmm......BOOST
  • Member For: 17y 9m 7d
:shocked:
if it's the original one
also check the alternator and check if theres any fluids leaking onto it that can kill them
Edited by our06t
