Alan_86 Inactive Members 1 Member For: 15y 22d Posted 18/01/10 12:36 AM Share Posted 18/01/10 12:36 AM Hi I have a XR6 BF 2005 Sedan 4.0L 6 speed with a strange problem. When the car is cold the engines starts fine but if I would to drive for over a certain time period and the car engine is at high temp , and the car has been turned off it will have some problem starting again until its cooled down. Need help in getting it fixed Regards Alan Link to comment Share on other sites More sharing options...
RHR BOOST Moderating Team 5,698 Member For: 21y 5m 4d Gender: Male Location: Southern Highlands NSW Posted 18/01/10 01:26 AM Share Posted 18/01/10 01:26 AM You might wanna check your coolant and have a mechanic change the thermostat. Sounds like its running hot and I could be putting the car into limp mode Link to comment Share on other sites More sharing options...
IBOO57 Member 538 Member For: 15y 7m 27d Posted 21/01/10 07:12 AM Share Posted 21/01/10 07:12 AM Does it still have the original battery?May be as simple as the battery having seen better days. Link to comment Share on other sites More sharing options...
our06t Mmmmm......BOOST Member 3,135 Member For: 17y 9m 12d Gender: Male Location: central coast Posted 21/01/10 07:17 AM Share Posted 21/01/10 07:17 AM (edited) if it's the original onealso check the alternator and check if theres any fluids leaking onto it that can kill them Edited 21/01/10 07:19 AM by our06t Link to comment Share on other sites More sharing options...
