ratter Member 6,793 Member For: 18y 8m 7d Gender: Male Location: @ my laptop Posted 08/10/10 06:00 AM Share Posted 08/10/10 06:00 AM Thing is though the 6T's will always be cheaper and easier to modify to get more hp.Why?fit an itercooler, change the pulley size and a tune and probably a lot more power on tap, it is reported that the motor will make power a lot higher in the rev range than what ford has it set to at the momment, so maybe ford has left a little more up it's sleeve for future models. Link to comment Share on other sites More sharing options...
7MA61 Member 471 Member For: 17y 5m 22d Gender: Male Location: Sydney Posted 08/10/10 06:00 AM Share Posted 08/10/10 06:00 AM Car mags reliable source I know seem to suggest it runs 0.1 bar less boost, so may be a slightly larger pulley. Could once again easily be fixed by buying a GT pulley & custom tune. Man they are going to struggle to clear old stock and used prices of the 5.4L is going to plummet haha. Link to comment Share on other sites More sharing options...
XtRmn8 570Nm @1800rpm Donating Members 2,441 Member For: 21y 4m 12d Gender: Male Location: Perth, WA Posted 08/10/10 06:00 AM Share Posted 08/10/10 06:00 AM Is it true the GS will be 315kw's?The drive train and engine on the GS is identical to the GT. The only difference between the two is in the tune. GS is 315kw/545Nm and GT is 335kw/570Nm. So potentially the GS should see bigger gains with a tune only.Both engines are limited to 6000rpm, while the NA 5.0 makes peak power around 7000rpm. Will be interesting to see what tune only gains area achieved.Also the GS only gets XR6T spec brakes. Link to comment Share on other sites More sharing options...
discostig Manual mode ________________________ All day, erryday Donating Members 13,798 Member For: 17y 2m 9d Gender: Male Location: Probably above atmospheric pressure Posted 08/10/10 06:02 AM Share Posted 08/10/10 06:02 AM (edited) Fuel use was measured using the official method and was mid 13's I think. Again, not bothering to dig up the link from the other forum One review mentions:We didn’t really drive for long enough at the launch to get a real-world fuel economy figure.The computer showed 15L/100km after the car was given a hard workout – not too bad at all. http://www.goauto.com.au/mellor/mellor.nsf/story2/AFD23AFF814CC352CA2577B3007B9A90ok edit again, couldn't help myself# 0-100km/h: 4.9 sec# CO2 Emissions: 324/325 g/km (man/auto)# Fuel Consumption: (ADR) 13.6/13.7 L/100km (man/auto)# Fuel Consumption: (As Tested) N/A# Fuel Tank Capacity: 68Lhttp://www.caradvice.com.au/85953/fpv-gt-gt-e-gt-p-gs-supercharged-coyote-v8-review/ Edited 08/10/10 06:13 AM by -SteveR- Link to comment Share on other sites More sharing options...
Guest EGOXRT Guests Posted 08/10/10 06:03 AM Share Posted 08/10/10 06:03 AM (edited) GS is 315kw and according to my Ford buddy, you can hardly tell the difference between the two.Ratter is correct, the 20kw difference is in the Calibration alone, apparently there is quite a bit of headroom..Oh, that particular car, with the leather, blah, blah, is a touch under 80k.The GS will be a good base for the modders.. Edited 08/10/10 06:05 AM by EGOXRT Link to comment Share on other sites More sharing options...
Dagabond Bored Member Administrator 35,722 Member For: 22y 2m 20d Gender: Male Location: Dé·jà vu Posted 08/10/10 07:08 AM Share Posted 08/10/10 07:08 AM Fark that sounds horn. Link to comment Share on other sites More sharing options...
Guest EGOXRT Guests Posted 08/10/10 07:11 AM Share Posted 08/10/10 07:11 AM Dags, go drive one when you can! Link to comment Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 8m 3d Gender: Male Location: Adelaide Posted 08/10/10 07:15 AM Share Posted 08/10/10 07:15 AM nice bit of gear this unit Link to comment Share on other sites More sharing options...
Turbo6FG Silver Donating Members 497 Member For: 14y 11m 1d Gender: Male Posted 08/10/10 08:32 AM Share Posted 08/10/10 08:32 AM Buy the NA & do your own supercharger kit. Then new 5.0 motor is a good starting point, apparently can rev a lot higher than the 5.4 used to. Link to comment Share on other sites More sharing options...
Maximus Member 1,627 Member For: 17y 10m 23d Gender: Male Location: Slip Sliding Away Posted 08/10/10 08:40 AM Share Posted 08/10/10 08:40 AM Why?fit an itercooler, change the pulley size and a tune and probably a lot more power on tap, it is reported that the motor will make power a lot higher in the rev range than what ford has it set to at the momment, so maybe ford has left a little more up it's sleeve for future models.I just see that alot of the Supercharged V8's need more $$$ thrown at them to get the same KW as people are getting from the 6T's.Maybe its different with this engine I dunno but only time will tell.Hope im wrong as the car in the video sounds like an aural orgasm. Link to comment Share on other sites More sharing options...
