CSP Member 89 Member For: 17y 4m 25d Posted 06/08/10 01:21 AM Share Posted 06/08/10 01:21 AM Fair enough Dagabond. Reasonable explanation. Link to comment Share on other sites More sharing options...
bunna Donating Members 813 Member For: 18y 30d Posted 06/08/10 09:29 AM Share Posted 06/08/10 09:29 AM But on topic, that's the general consensus around here too. A 5k increase for just a motor is a bit steep in the publics eyes. New stripe packages won't cut it either. Needs to be something else...Just a motor? why is it not worth an extra 5k? heck - everyone pays an extra 4k for just a turbo! Not to mention every FPV owner who saw fit to fork out tens of thousands extra for some stickers and more power Fact is the buying public will decide whether this very different powerplant is worth the extra dough and the sales will tell the tale. My guess is f*ck yes. Link to comment Share on other sites More sharing options...
IBOO57 Member 538 Member For: 15y 3m 11d Posted 06/08/10 11:00 PM Share Posted 06/08/10 11:00 PM (edited) The wait for this has gotten a bit boring.....I was amped to see what was happening 3 months ago but now im sick of waiting.Could it be that Ford is just waiting for sales on the the old Nugget 5.4 to finishbefore releasing the new Motor?Not sure why anyone would buy one though knowing the new ones around the corner. Edited 06/08/10 11:01 PM by IBOO57 Link to comment Share on other sites More sharing options...
tquarrell Member 181 Member For: 20y 1m 21d Gender: Male Location: Sydney, NSW Posted 08/08/10 03:47 AM Share Posted 08/08/10 03:47 AM Looking forward to seeing these things but was kind of hoping they'd use the real new boss engine, the 6.2 sohc (the new block with wider bore spacing) that they replaced the 5.4 with in the states in the F150 raptor truck, rather than the coyote (from what I understand is a bored out 4.6). 309kw @ 5500rpm and 588nm running 9.8:1 compression in truck trim on any grade fuel http://www.meadowlandford.com/ford-6.2l-engine-specs.htm, if FPV had of bumped the compression or even just changed the cams or tuned it for premium I'm sure it would of been more than competitive with the ls3 chev. I've also heard that Ford US have already developed a 7.0 litre version of this engine and fitted DOHC heads, producing upto 800hp in their drag race testing programe aspirated.. Link to comment Share on other sites More sharing options...
(BOOSTN) Member 25 Member For: 14y 2m 13d Posted 10/08/10 01:40 AM Share Posted 10/08/10 01:40 AM twin turbo v6 or the v8 is the way to go... Link to comment Share on other sites More sharing options...
f-wolf Member 897 Member For: 17y 5m Gender: Male Location: ACT Posted 24/08/10 11:22 PM Share Posted 24/08/10 11:22 PM 3.17 MB file at :http://www.goautomedia.com/mellor/enews.nsf/edition/EF0A7711E7054B5CCA25778900024526/$file/GoAutoNews_546.pdf Link to comment Share on other sites More sharing options...
rockafellqeinstien Member 325 Member For: 16y 2m 2d Posted 25/08/10 12:35 AM Share Posted 25/08/10 12:35 AM I am very interested in the new V8 but realisticaly I wont jump in until its had time to prove itself. I give it 2 years befor I consider changing.I am guessing that this engine will be with falcons for a long time (longer than the 5.4) and they arnt going to release it in maxed out form straight away. People will make the move anyway even if its only a slight power jump and then they will slowly up the power over the next 5-10 years. Remember the LS1 came out with 220kw and slowly crept up over time.Two big questions for me will be 1) entry level tuning potential (injectors/cat/exhaust/IC) of the lowest S/C version (GS or xr8). If I can get 350rwkw and 850+nm for a couple of extra grand I'd be happy as this is 50rwkw up on what you can get out of a xr6t for the same tuning $$$ (the sound of a V8 that doesnt go through a turbo is schweeeeeet) 2)will the drive line components stand up to it? I do alot of KMs and the turbo's power delivery seems to be kind to the current components. A SC V8 might be a bit to sharp in its responce and I dont want to have to be replacing drive line bits every 20,000 kms. Link to comment Share on other sites More sharing options...
CSP Member 89 Member For: 17y 4m 25d Posted 25/08/10 05:31 AM Share Posted 25/08/10 05:31 AM info will be revealed on Thursday (next week). Link to comment Share on other sites More sharing options...
Ras351 Member 219 Member For: 16y 5m 20d Gender: Male Location: Newcastle Posted 25/08/10 09:24 AM Share Posted 25/08/10 09:24 AM I won a competition called Ultimate Ford Experience which was run by Ford Australia to celebrate the 50th Anniversary of the Falcon. We got to meet Marin Burela, go on tours of the design studio, the assembly plant, the engine assembly plant, the sheet metal stamping plant and go for laps around the test track (high speed and durability loops) at You Yangs Proving ground. Oh yeah and have lunch with Marin, Allan Moffat and Dick Johnson at the Ford Discovery Centre.ANYWAYWhilst at the design studio I saw the rear bar of the new XR8 being milled out of clay (clay model) and the XR8 had the quad pipe setup for the new V8. So that would pretty much confirm XR8 is still around.Later in the day at the proving ground when I was in the new FG Turbo ready to do some hot laps with the test driver we had to wait for the new GT test mule to drive past us so we could cross the high speed bowl. It pulled up right near us and then just launched it off the line through the first couple of gears. OMG I can confirm it sounded SO TOUGH while doing it. Once again it had the quad pipes under the rear bar.Our test driver said "I can't believe you guys are actually allowed to see this" etc etc.It was pretty epic and sounded awesome.The ride around the test track in the FG Turbo was insane. It was wet and we were doing around 150km/hr around these chicanes and the way the thing held on with the T/C working overtime was extremely impressive. It made my BF's system look prehistoric. We hit 205km/hr down the back straight then hard on the anchors into this tight hairpin left. Even the stock brakes are a step up over the ones in my BF imo. The driver Shane was so good! He used to work for Bently as a test driver there but now obviously works for Ford Aus. Him and another guy get to thrash XR6 Turbo's and XR8's around that track all day. Dream job. Link to comment Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 5m Gender: Male Location: Brisbane Posted 25/08/10 11:37 AM Share Posted 25/08/10 11:37 AM Bastard. Not the testdriver...you! Would have been awesome. Link to comment Share on other sites More sharing options...
