Fpv To Supercharge New 5.0-Litre V8 To Give Ford A Power Boost To Riva
  • Replies 698
  • Member For: 17y 7m 11d
Makes me wanna go and apply for a job at Ford! The trickle is infuriating at times :roflmbo:
  • Member For: 21y 4m 21d
Few things I noticed:
No HID's, I mean geez Ford it is 2010, they stick them on most modern cars now :roflmbo:
The rear wheels look the same width as the front, if it is a SC V8, then it has better get a min 275 wide rear
I also cannot se an intercooler there. It looks the same as the fron of my car. The bits of silver are the aircon and trans coolers. Have a look at a F6 front and you can see a intercooler like dogs balls :bum:
  • Member For: 16y 11m 9d
As for the intercoolers, on these types of engine/supercharger combos the norm is to use water to air coolers.
The cooling device normally looks more like an air con condensor, not the usual air to air type coolers you are used to seeing on XR6T's.
Remember these coolers are cooling the water/coolant mix, not the actual air charge.
The air charge is cooled by the cooling unit under the supercharger.
  • Sucker
  • Moderating Team
  • Member For: 21y 2m 10d
just happened to stop 100 meters from the front gate to pop the bonnet....
Probably broken-down and awaiting Ford Assist to turnup? :buttonit:
  • Member For: 18y 2m 5d
The issue is obvious as it can been seen in the current cars. The extra power and torque just take it over the limit and causes failure.
There's 2 ways to fix it... the expensive (and arguably proper) way, or the cheap way, which plays havoc with NVH but solved the overall issues. I expect FPV will take the cheapest and easiest route and hopefully not compromise NVH too much..
