Turbo Oil Drain
messna
  • Member For: 16y 3m 5d
the braid it self is $1 per cm and the two end fittings are $30 each they now have done one so the cost would be cheaper.
  • Moar Powar Babeh
  • Member For: 19y 5m 16d
That style of braided line has a teflon lining. This hose is normally used in fuel and air delivery and occasionally for turbo oil supply applications. all low pressure, low heat applications.
I dont mean to rain on your parade but i think the heat from the turbo and the high oil temp associated with the drain with cook the teflon and it will leak through the braid in time
Once it was been installed and heat cycled a couple of time be careful to avoid flexing the hose as this can crack the teflon lining once its taken a heat set.
  • Member For: 17y 1m 21d
I had this on my high mount, lasted a week. then had numerous "heat proof" pieces of rubber oil pipe that were also insulated by a fire proof fibreglass cover. all turned black and crumbled. it has to be all metal, no closer than 5-6cm to the manifold for the rubber/teflon braid. stock oil drain is $140 from ford.
  • 2 weeks later...
