  • Member For: 17y 8m 8d
Hey Leo. Yep, Seven Hills is their location. And I don't think most businesses would warranty a product in the situation you describe unfortunately. They don't build boxes AFAIK.
For your own pieve of mind, I think it would be better to give me a yell when it comes time to needing a converter. I'm sure I can get a better than retail price for you. When you buy one, I'm sure you could pick it up if that's more convenient.
  • Member For: 17y 10m 1d
in the simplest of terms it means fast take off from a standstill :-), if you would like a essay about it ask someone else I cbf..lol
The converter is basically a fluid coupling between the engine and transmission. It creates a load on the engine. When the stall speed is increased (by fin angle as I understand it), more revs are required before forward drive is achieved. The stall speed typically refers to the RPM required to start the drive wheels turning with the brake on. Remember though that when the brake is not on there is less load, so you need more rpm to get drive. A 2800rpm converter may flash to 3200 or more rpm depending on the load and gear you're in. You basically want to match the stall speed to your engines characteristics in order to take advantage of it's power band. If your donk doesn't start making good boost until 4000rpm, a suitable matched converter will allow the revs to rise to near 4000rpm, allowing your engine to come on full boost a lot quicker. I think I've covered the basics in laymen's terms :)
With the standard turbo on our cars, getting near 3000rpm is what most people would consider ideal as the turbo will produce good boost by then and not be so loose as to rob power. Getting a converter that's too "loose" will start robbing you of power and as Lee (dalts) has reported, make you go backwards in terms of MPH and ET.
Edited by straughsberry
  • 2 weeks later...
I've been flat out over last 2 weeks and I'm heading away so I'll get onto a group buy when I get back. I'm away for 6 days.
  • New Member
  • Member For: 16y 6m 11d
If your looking to purchase the best torque converter on the market for a 4spd trans then call Tony dominello.
Tony is the man behind the majority of fastest automatic tranmission equipped BA-FG's coming out of the big name workshops. I have recently fitted one of his garrantteed to handle 500rwkw 4spd box and converters to my T and cold not be happier.
  • Member For: 16y 11m 15d
dominellos certainly have the reputation when it comes to transmissions, especially the btr 4spd. he probably outsource's the stall work and could quite possibly be the company that staughsberry is reffering to.
