xr6t_ute Donating Members 2,281 Member For: 17y 10m 1d Gender: Male Location: south east suburbs Posted 11/01/10 12:08 PM Share Posted 11/01/10 12:08 PM (edited) yes all the late model autos are zf kyle, I think from memory mauz's f6 had his stall modified 200rpm more than std and that's as far as u can go.anything more than that and its limp mode.Im sure someone could enlighten us more on the subject, give kewish a call they did all the work.A convertor is not really needed on the zf auto as a few guys have run 1.6 60fts with the zf, one of problems with building up boost on the line with the zf is the tailshaft, have a look at some previous threads on this. Edited 11/01/10 12:12 PM by xr6t_ute Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-969939 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 8m 15d Gender: Male Location: Melb Posted 11/01/10 12:33 PM Share Posted 11/01/10 12:33 PM On 10/01/2010 at 3:09 AM, straughsberry said: BTW, I don't run a trans cooler with 370rwkw and I haven't had a single sign of a problem from the auto in 18 months+. But I'd put that down to RVO's care in building the things.The build of the auto has nothing to do with needing a trans cooler. There's 2 major reasons why people put trans coolers on.The first and most important is to BYPASS the cooler in the radiator.. If you saw what it looked like, especially after a tranny failure. You'd want to change it also. They clog up and cause earily tranny failure.And of course the second, being a better cooler than the radiator cooler. a Stall convertor Produces more heat, PERIOD. Heat is bad as it thins the oil, and essentially causes slip. On 10/01/2010 at 5:46 PM, icer said: Also ask for a TCE not a dominator. Especially if you go through bayswater auto's. I had heaps of issues with their auto and with thier dominator convertor.Your convertor problems were nothing to do with TCE / Dominator. Turns out there was a problem with the Dominator once they split it. Depending on the turn around time for the auto, they will either use TCE or Dominator. TCE is prefrence based on experiance anyways.If you were to get a convertor, You wouldnt get a factory modified one. You can only go so far without loosing too much positive drive. Ideally you wanna go a smaller diameter convertor. But in going smaller diameter convertor, You also loose Oil capacity = need better cooling capacity.Stall speed isnt based on "wanting" 2800rpm. Its based on the torque your engine produces. More torque. The tighter the convertor will be.. Ie, 2 identical convertors in 2 seperate cars. one will do 3000rpm, and the other will do 2600rpm. Clearly the one that does 2600rpm produces more torque.There was a hell of a lot more information I posted here, but I lost it pressing undo too many times. and I cbf re-typing it all. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-969946 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 8m 8d Gender: Male Location: Broady, Melbourne Posted 12/01/10 02:57 AM Share Posted 12/01/10 02:57 AM On 11/01/2010 at 12:33 PM, Headsex said: The build of the auto has nothing to do with needing a trans cooler. There's 2 major reasons why people put trans coolers on.I think you missed the point of what I said. The point was that even without a cooler, (which we all know keep temps down and can increase the lifespan of your auto due to it's heat reducing function) my trans has lasted 18+months with 370rwkw and it still feels snappy as bro. So with a cooler, it is more than likely some time would be added to it's lifepsan. My other point was that the longetvity and reliability I am current enjoying has to do what I think is build quality. Capiche! Looking back at what I said, I don't see where I intimated that the the build of the auto has something to do with needing a trans cooler. And by it's very name "trans cooler" I'd say it would be fairly easy to determine that the need for a trans cooler is dictated by the fact that you need to cool your trans So if your trans temps are getting too hot too often, you probably should get one. Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970048 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 8m 15d Gender: Male Location: Melb Posted 12/01/10 06:20 AM Share Posted 12/01/10 06:20 AM I'll highlight the part.... straughsberry said: BTW, I don't run a trans cooler with 370rwkw and I haven't had a single sign of a problem from the auto in 18 months+. But I'd put that down to RVO's care in building the things.in saying that..RWKW has nothing to do with it either.. I could have 500rwkw, but drive it like a grandma.. Without a trans cooler.. I can tell you my auto will last at least 3 years that way. Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970102 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 8m 8d Gender: Male Location: Broady, Melbourne Posted 13/01/10 05:45 AM Share Posted 13/01/10 05:45 AM No worries mate. Have fun driving like a grandma For those interested in one of these converters they normally retail for $495. If we can get 5, the price will be $395. plus about $20 for delivery. Also, there is usually a $100 core charge but I've worked out a deal so you will not have pay a core charge and in fact, you will not have to send your old converter back at all. If we get below 5, they will be $445.So how about a show of hands. If 2 or 3 people are interested, I'll start a group buy and if it goes through, I'll run it for 2 weeks with payments to be made within a week after that.The converter's rated stall is 2500-3000rpm with most being around that 2700rpm mark. Now as we all know, it can be a pain trying to get a converter right because of differences in tunes. The good news is you will be able to send your converter back if it's outside of the rated stall speed range and try another one. Postage back to Torque Converter Industries will have to be paid by you though. And the converter will come with a 12 month warranty.Cheers,Steph. Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970398 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 10m 1d Gender: Male Location: south east suburbs Posted 13/01/10 05:54 AM Share Posted 13/01/10 05:54 AM that's a pretty good price, what 60ft have u managed with this convertor? Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970403 Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 8m 8d Gender: Male Location: Broady, Melbourne Posted 13/01/10 06:00 AM Share Posted 13/01/10 06:00 AM I haven't ran with this converter. But I'd say it would definitely be an improvement over stock. After fitting this converter and new coilpacks, I didn't loose any power. In fact, I picked up 20 odd rwkw after a retune with the new coilpacks and this converter. Want to be a guinea-pig!? Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970404 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 17y 10m 1d Gender: Male Location: south east suburbs Posted 13/01/10 06:06 AM Share Posted 13/01/10 06:06 AM lol I already have a custom made unit in my ute, it is a 245mm ,smaller in diameter than the ones you guys run. Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970406 Share on other sites More sharing options...
JVK Silver Donating Members 751 Member For: 19y 4m 8d Gender: Male Location: North West Hot Hell,VIC Posted 13/01/10 06:22 AM Share Posted 13/01/10 06:22 AM The motor that has the most torque out of the identical cars will be the one that has the higher stall speed provided the convertors are the same. Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970413 Share on other sites More sharing options...
XR64LT Donating Members 678 Member For: 17y 3m 18d Gender: Male Location: sydney Posted 13/01/10 07:50 AM Share Posted 13/01/10 07:50 AM hey staughsberry I am very interested this convertor although I dont have the funds to get the box built as of yet. The point im trying to make is I guess, I dont want buy the convertor and have it sitting there for 12months then the warranty is void by the time it is installed. Is there anything that can be done in that regards or it just tuff titties? Does TCI build gearbox or just manifacture the convertors too, I heard they are around seven hills area, I am right around the corner so perhaps I can just pick it up?Leo Link to comment https://www.fordxr6turbo.com/forum/topic/64980-stallie/page/3/#findComment-970439 Share on other sites More sharing options...
