Bov Muffler
power_slide
  • MattyP
  • Cruise Control
  • Member For: 12y 8m 28d
Pics aren't loading on mobile
Is recirculating or vent to atmosphere?
Plaz intakes are notorious for turbo flutter
Is that what you are hearing?
  • Replies 22
  • Bronze Donating Members
  • Member For: 11y 7m
Run a longer length of hose from the valve to the intake? like coil up a meter of hose? Got me a little concerned now. I'm planning a similar thing but utilising an FG cross pipe & Turbosmart kompact 32mm recirc. Hoping the run from the TB relocation & the pipe will shut it up a bit
  • Member For: 12y 19d
Sorry Mattyp I think you are correct. It's turbo flutter. Sorry for the lack of sound in the vid may need to turn sound right up. F__ken iPhone always fails when you need it to do something simple.
trim.945A9446-A998-430C-92FA-0A46D525C788.MOV
Edited by slygary
  • XR50T
  • Member For: 11y 9m
If it's a turbosmart valve it is adjustable, just loosen it until it stops the flutter, but stays closed on vac.
If it's too tight it won't be opening up properly or won't respond quick enough.
Also they can seize up a bit, give it a clean and a bit of oil and should be sweet.
