  • Member For: 15y 8m 29d
Hey guys,
Basically I thought id be easier to get a 12inch sub and enclosure, take the wires from the 8inch and connect them to the 12 inch that will be in the boot.
Is it that easy? If not please give me a quick rundown.
Cheers guys!
https://www.fordxr6turbo.com/forum/topic/64962-running-12inch-sub-of-premo-amp/
  • Member For: 16y 7m 8d
I guess u could, but I think you will not get much more noise coming from the 12" than the 8". I dunno the specs on the amp but im pretty sure it would not be powerfull enough to get the 12" pumping.
Thanks ;o
Ill see if anyone else has any ideas.
Somebody did post the specs of the amp a few days ago, From what I understand of how they work, It should be enough. But as I said, I'm not the best at car stereo ;p.
Edited by xr6t 4.0
  • It's not a MKI!
  • Member For: 16y 10m 25d
Don't bother, you'd be wasting your time.
You can use the cables that go to the factory sub as line level inputs into a decent amp, but running a 12 off the factory amp will not work to your expectations.
smicky may be a long shortly with a list of combinations depending on how much money you want to spend.
By the sounds of things you'll need to get it installed professionally as well.
~ By the sounds of things you'll need to get it installed professionally as well.
Haha, Oh too true. Made me laugh :bopp:
I want to spend no more then $500 on everything.
Just got a new position at work so time to get modding :D
  • Member For: 18y 8m 5d
If you want to run a new sub off the factory amp you will need the lowest powered 12" you can get your hands on and put it in a ported box. We have done plenty like this and while it is only slightly louder than the factory sub it does sound much better and play lower frequencies. If you do want considerably more bass then you will need an amp and woofer matched to each other. $500 will get you something half decent with installation. $700 or $800 would be better if you could hold off a week or two
  • Go Pies!!!
  • Member For: 17y 2m 28d
Ha a ha hahahaha - your always dobbing me in aint u mate!
:innocent:
$500 for a 12" and amp... hhhhmmmm
Go and get a 10" with a good amp for 500$ and you should be ok...
Dont bother with the 12" unless u want to spend more, or seriously there isnt much point in going 12" of 10" if all your doing is sub and not the rest of your system... even then 9 out of 10 people are better off with a 10" then 12's or 15's that they use... its all just :bopp: in most cases and most people think bigger is better... not always the case...
What do u want the sub to do?
what sort of tunes you listening to?
What r u hoping to get from upgrade?
  • Go Pies!!!
ministry as in MOS? (dance/trance etc.)?
Id look at a good quality 10" system ported - faster response, and 'generally' punchier bass to a 12"...
:buttonit:
In that price range - JL, Pioneer, Clarion, Boston Sub. With a Amp from one of those runs as well...
Might get u hitting a little more then $500 once you include a wiring kit, box (if you are not going to build/design it yourself), box components (filling, ports etc if not already pre-fab), and install... but it will have you smiling from ear to ear and shouldn't be over kill for the rest of the stock system...
Amp+Sub - should be 'around' the 650$ I would guess... just depends on how good you can bargin...
Ryda, JB Hifi, or your 'good' local car audio store should be able to help you out...
Hope this helps!
:buttonit:
just an idea:
bridge amp...
Ryda Car Audio - Clarion Car Audio APX2181 Car Amplifier($221.05)
sub...
Ryda Car Audio - Boston G210-4 10" Subwoofer($277.25)
just an idea...
remember whatever the subs power requirements are say 200w, make sure the amp is able to powering the sub... so 250w amp...
