power_slide Hitting the apex Donating Members 596 Member For: 16y 4m 14d Gender: Male Location: Miranda Posted 07/01/10 10:44 AM Share Posted 07/01/10 10:44 AM Hey guysJust got the ute back from the shop and I am really happy with the resultI Have just installed my process west stage 3 intercooler With CAI and throttle body relocationThis is on top of bosh green top 42lb injectors, 4" exhaust + walbro pumpDidnt want to push it any further with the stock cottom endSo the final was 371.9 rwkw at 15psiSuspension is next Link to comment Share on other sites More sharing options...
F6turbo Member 172 Member For: 18y 9m 1d Gender: Male Location: Sydney Posted 09/01/10 11:24 AM Share Posted 09/01/10 11:24 AM that's some good power your car is making there. Have you had the wastegate ported or done the actuator? Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 4m 14d Gender: Male Location: Miranda Posted 09/01/10 11:53 AM Author Share Posted 09/01/10 11:53 AM Na mate havent touched the turbo, my tuner told me I dont need to spend my money on changing the actuator as the boost is controlled by the ecu, and as the chart shows it is looking ok... havent worried about porting yet either as it dosent seem to be a issue yet Link to comment Share on other sites More sharing options...
falcon_6 Member 29 Member For: 16y 6m 3d Gender: Male Location: Bringelly NSW Posted 10/01/10 12:01 AM Share Posted 10/01/10 12:01 AM On 09/01/2010 at 11:53 AM, power_slide said: Na mate havent touched the turbo, my tuner told me I dont need to spend my money on changing the actuator as the boost is controlled by the ecu, and as the chart shows it is looking ok... havent worried about porting yet either as it dosent seem to be a issue yetLooking at your dyno charts, its impossible for your turbo to hold boost the way it is at that power level without having boost leak.These 35/40 turbos are internally gated and cannot handle big boost levels even when ported.It seems to me like your turbo has already been moded. Link to comment Share on other sites More sharing options...
Corzza 777 Member 7,135 Member For: 16y 1m 3d Gender: Male Location: Neutral Bay. Born and Bred in the RSA Posted 10/01/10 12:11 AM Share Posted 10/01/10 12:11 AM Top result! Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 4m 14d Gender: Male Location: Miranda Posted 10/01/10 01:32 AM Author Share Posted 10/01/10 01:32 AM On 10/01/2010 at 12:01 AM, falcon_6 said: Looking at your dyno charts, its impossible for your turbo to hold boost the way it is at that power level without having boost leak.These 35/40 turbos are internally gated and cannot handle big boost levels even when ported.It seems to me like your turbo has already been moded.After reading the forum I thought the same thing so I started enquiring at pulse the cost of doing the actuator as it seemed to be the cheaper of the 2 options when I was told I can do it but its a waste of money by joe at pulse.I did not do any work for the first 100,000 ks as I wanted to use warranty seeing its a work horse. the last 10,000 k I have done all the modsat 80k ford had to machine the head so im guessing they took the turbo off then but that is the only time it has been taken off. and I dont think they would have changed the actuator or ported it under warranty.I guess it is possible to leak and maybe they have accomidated for this in the tune. is there any way the chart can show a false reading? Link to comment Share on other sites More sharing options...
power_slide Hitting the apex Donating Members 596 Member For: 16y 4m 14d Gender: Male Location: Miranda Posted 10/01/10 01:40 AM Author Share Posted 10/01/10 01:40 AM Thanks corzza, its alot of fun Link to comment Share on other sites More sharing options...
The_Bogan Donating Members 881 Member For: 17y 11m 1d Gender: Male Location: Brisbane, Queensland Posted 10/01/10 09:35 PM Share Posted 10/01/10 09:35 PM hows about the date on the dyno sheet???didnt know they brought out xr6 turbo's in '99 Link to comment Share on other sites More sharing options...
Dirty32 Legendary member!! Donating Members 1,739 Member For: 18y 1m 11d Gender: Male Location: Dianella, West Oz Posted 11/01/10 01:38 AM Share Posted 11/01/10 01:38 AM Do you know what duty cycle your injectors are running at?Would have to be very close to maxxing out - potentially running lean at WOT...?I was under the impression that the Bosch 42's werent much good for anything over and above 340rwkw? Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 1m 14d Gender: Male Posted 11/01/10 03:17 AM Share Posted 11/01/10 03:17 AM I have ALWAYS said green tops are good for 500whp. Link to comment Share on other sites More sharing options...
