Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 12d Gender: Male Location: Perth Posted 30/07/12 01:57 PM Share Posted 30/07/12 01:57 PM I'll happily take that nizzer plenum off your hands PM me if your keen mateI wont be changing, The Oracle has talked me out of it. Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1272828 Share on other sites More sharing options...
allmtr Member 512 Member For: 16y 1m 28d Gender: Male Location: Newcastlish Posted 30/07/12 02:43 PM Share Posted 30/07/12 02:43 PM f*ck me, if I didn't have bad luck, I'd have no luck at all. I bought a 6mm drill bit that is etched as being 5mm so now I have over drilled the TB holes....I don't know what I am going to do, I really don't want to get them welded up and start again...I can fit nuts on the bolts but it'll look a bit bodgeAAAAAAAAAAAAAARRRRRRRRRRRRRRRRRRRRRRRGGGGGGGHHHHHHHHHHHH Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1272837 Share on other sites More sharing options...
F1PERFORMANCE Donating Members 104 Member For: 16y 1m 22d Gender: Male Location: VIC Posted 30/07/12 03:06 PM Share Posted 30/07/12 03:06 PM helicoil them and no 1 will ever know + stronger Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1272840 Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 9m 9d Posted 31/07/12 08:51 AM Share Posted 31/07/12 08:51 AM Can u go to an 8 mm bolt?Sent from my HTC Velocity 4G using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1273114 Share on other sites More sharing options...
F1PERFORMANCE Donating Members 104 Member For: 16y 1m 22d Gender: Male Location: VIC Posted 31/07/12 09:54 AM Share Posted 31/07/12 09:54 AM (edited) 8mm is a very common bolt size but the helicoil should able you to keep the bolt size std as you need to drill larger than the bolt you have as you have to wind in the new thread. Edited 31/07/12 09:56 AM by F1PERFORMANCE Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1273174 Share on other sites More sharing options...
turbowelshy89 Member 147 Member For: 14y 9m 9d Posted 31/07/12 10:02 AM Share Posted 31/07/12 10:02 AM 8mm is a very common bolt size but the helicoil should able you to keep the bolt size std as you need to drill larger than the bolt you have as you have to wind in the new thread.Good point but it was just as a maybe if he's unable to get a helicoil. But yea like u said it would be better to helicoil as u get to keep the standard size bolt but if not then ud just have to check if an 8mm bolt with fit through the holes in the tb.Sent from my HTC Velocity 4G using Tapatalk 2 Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1273184 Share on other sites More sharing options...
allmtr Member 512 Member For: 16y 1m 28d Gender: Male Location: Newcastlish Posted 31/07/12 10:10 AM Share Posted 31/07/12 10:10 AM Yeah it's going to have to be bolts and nuts unless I weld up these holes and start again. There isn't enough meat in the casting to enlarge the hole to more than 6mm Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1273190 Share on other sites More sharing options...
F1PERFORMANCE Donating Members 104 Member For: 16y 1m 22d Gender: Male Location: VIC Posted 31/07/12 10:13 AM Share Posted 31/07/12 10:13 AM (edited) I pretty sure the dill size is a tad over 6mm in alloy for a helicoil Edited 31/07/12 10:14 AM by F1PERFORMANCE Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1273193 Share on other sites More sharing options...
allmtr Member 512 Member For: 16y 1m 28d Gender: Male Location: Newcastlish Posted 02/08/12 08:23 AM Share Posted 02/08/12 08:23 AM Fuel lines done and final ass'y begins 1 Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1273816 Share on other sites More sharing options...
allmtr Member 512 Member For: 16y 1m 28d Gender: Male Location: Newcastlish Posted 03/08/12 07:16 AM Share Posted 03/08/12 07:16 AM (edited) Work continuesReally need to swap that blue silicon hose with black Edited 03/08/12 07:18 AM by allmtr Link to comment https://www.fordxr6turbo.com/forum/topic/64843-fg-manifold-conversion/page/18/#findComment-1274201 Share on other sites More sharing options...
