  • Member For: 16y 3m 17d
Got some hose to replace the thermostat piping today. Managed to get the loom to sit in the V of the starter and it's solenoid. Had to split the 4 and 5 injector wiring as 5 was getting a bit of tension on it.
Got a tap and 5mm drill bit so that I can redo the Tb holes in the manifold. I don't know how anyone runs a spacer with the clearance that there is. I've organised for my mate to weld up the holes when I stuff it up....
Extended the loom for the boost sensor today. Ended up 5 1/2 feet long. Running it under the thermo fan cover where the hose runs from the thermostat housing to the expansion bottle then up under the manifold to the sensor mounted in the Process West Elbow.
Need a flared hose to adapt the BF blow off valve to the PW elbow
Mostly done now
Need injectors and a reducer from 32mm to 25mm for the BOV. Also going to replace the blue silicon with black and satin black the alloy piping.
  • Moar Powar Babeh
  • Member For: 19y 9m 1d
Mcmerge....
Keen as mustard to see this thing run. I like the idea of the FG Plenum, Anybody want to buy a Nizzer Plenum....?
Who's tuning it mate?
