Fg Manifold Conversion
Guest EGOXRT
  • Member For: 19y 6m 22d
Your local stealer (dealer..) should be able to give you a part # for the manifold. I bought mine off a forum member who had contacts at Ford. It needed a little tidying up as it turned out to be a prototype manifold, without any part nos. on it but has worked flawlessly on my Territory turbo. A standard FG fuel rail also lined up perfectly (make sure you use the correct fuel pressure regulator) with 5mm spacers to match the Siemens Deka 60lb injectors I used.
People have used this manifold, in standard spec, to make over 600rwkw so its not bad and if you find it second hand, a cheap way to make good power. Hope this helps you a bit.
Cheers.
  • Member For: 15y 11m 2d
Cheers.
Thanks, yeah I'll try a dealer when I get a chance. A mate might be able to get me dealer pricing and was after the part number to check.
  • 1 month later...
Ordered my FG manifold today from Fraud. Going with the Plazmaman fuel rail. I think I'll weld up the manifold and drill/tap the TB holes to avoid the adapter issues
Anyone know if BA/BF throttle bodies are the same diameter as FG? ie if I fit a BF TB to the FG manifold, will I be able to use an FG aftermarket elbow?
I got dealer pricing so was around $550
Ordered a BF TB gasket today so I can figure out the best way to adapt it to the FG manifold, should be in tomorrow
BF throttle body gasket on FG manifold
Probably going to weld up old bolt holes and drill/tap new ones. I was surprised the bore is bigger on the BF
  • Member For: 17y 8m 14d
550 is pretty good, better then B series but wonder how it compares to an aftermarket plenum?
