  • Dropping a turd
  • Member For: 17y 5m 30d
  On 19/07/2013 at 4:14 AM, xjr said:
Arronm,
is that a bolt-on to the FG Mal Wood shifter?
No its a BA BF.
It looks like the FG bolts 90 degrees to the shift direction, so a hurst wont fit unless you put a swist in it.
Edited by arronm
  • 2 weeks later...
  • Member For: 13y 2m
  • 2 weeks later...
  • Member For: 12y 3m 13d
Installed a Aeroflow short shifter in my FG MKII and absolutely love it, gear shifts are nice and tight close together. I did the same as Rancidpunx and changed the oil while I had the car jacked up and the old shifter off the box, I used Castrol Dex III as recommended in the owners manual and also had a use only Dex III sticker on the gear box.
  • 4 weeks later...
  • Member For: 15y 2m 20d
Hey mate when you installed your aeroflow shifter did you have to adjust the stops much from the position in the photo or was it pretty spot on out of the box im gonna install mine this Saturday
  • 2 weeks later...
  • 2 weeks later...
  • 5 years later...
  • New Member
  • Member For: 5y 11m 23d
  On 17/07/2013 at 12:27 PM, arronm said:
Is that green thing the standard shift stick.
I like the strong spring and the short of the my malwood in my typhoon. Also removing the rubber bush really firms up the feel.
What I dont understand is why people fit a very short stick which reduces the leverage to smash those shifts. Plus its closer to the steering wheel.
Malwood plus hurst.
Expand
Where did you get that shifter boot?!
I have the shifter and everything else and cant seem to find a shifter boot anywhere that will fit easily like that!
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 16d
it doesn't fit easily... when you buy the hurst bar, you get a little bit of plastic that goes around it, which is visible in this pic. The "surround" is the stock one in an F6. :Welcome2FordXR6t:
