John_K Donating Members 438 Member For: 16y 5m 11d Gender: Male Location: Sydney Posted 28/12/09 04:27 AM Share Posted 28/12/09 04:27 AM Guys,I'm after some help.Today I upgraded my ICC from the standard LCD screen to a premium colour TFT screen.I removed the top and bottom plug-in sections from my original ICC and transplanted it to the premium unit.Everything plugged up, the car started fine however the screen shows this:I found out that it accepted a CD and after a little while of mucking around, it actually turns on when I hold down the FM and MENU buttons for about 5-10 seconds with the ignition on.When I turn the ignition off and then back on again, I get SECURITY CODE ERROR again. Holding down FM and MENU turns it back on again, but I don't want to have to do this all the time.The memory for the audio settings and CD seem to keep, but the FM station presets don't hold.Is there a way for me to DIY fix this, or do I have to take it to Fraud? Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/ Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 10m 9d Gender: Male Location: The 8th Dimension Posted 28/12/09 04:32 AM Share Posted 28/12/09 04:32 AM You have to go to fraud, to get it unlocked Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-966411 Share on other sites More sharing options...
John_K Donating Members 438 Member For: 16y 5m 11d Gender: Male Location: Sydney Posted 28/12/09 06:04 AM Author Share Posted 28/12/09 06:04 AM Bugger! A little more info. While driving, it stays on for about 3 to 4 minutes before switching off and coming up with SECURITY CODE ERROR.The good thing is that all the air con settings still work. Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-966426 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 9m 29d Gender: Male Location: Aspendale, Vic. Posted 18/03/10 09:03 AM Share Posted 18/03/10 09:03 AM so u had to go to ford to fix security code issue? Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-992332 Share on other sites More sharing options...
CHLAXN Donating Members 932 Member For: 16y 11m 24d Gender: Male Location: north QLD Posted 18/03/10 09:25 AM Share Posted 18/03/10 09:25 AM hi mate I had the same thing happen when I installed my pw surge tank.. car would only click and not kick over.. it had security code error come up and I rang ford and they were no help at all.. I removed the + on and off the battery a few times and letting it sit for a while and it cleared its self and started.. did the same as you looked at every fuse and relay changing them but that did nothing too.. probably no help to you *Beep* but that's what I did to my f6 and it eventually worked after 2 hours of stuffing around pulling my hair out lol.. Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-992343 Share on other sites More sharing options...
robyread Inactive Members 1 Member For: 16y 9m 15d Posted 08/05/10 03:44 PM Share Posted 08/05/10 03:44 PM Hey mine come up with the same error and the car starts fine.. but all the warning lights on my speed cluster start pooping up and the speed and rev guage doesnt work.. anyone know whats wrong??-rob Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-1006052 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 3m 2d Gender: Male Location: Sydney Posted 08/05/10 09:40 PM Share Posted 08/05/10 09:40 PM You will usually see this on the ICC everytime you remove the battery. If you have not swapped the ICC, it should go away after you turn the car off then on again.If you did swap the ICC, then you will need to get Ford service to "pair" the ICC to the car. If you change from a low series ICC to a high series ICC it can stop the car from starting.Roby, you will need to tell us if you did anything to the car to create this problem, also the forum Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-1006073 Share on other sites More sharing options...
arm79 Donating Members 214 Member For: 16y 2m 20d Gender: Male Location: Melbourne Posted 13/05/10 12:58 AM Share Posted 13/05/10 12:58 AM Loose plug somewhere?Maybe on the BEM under the ICC, some of those plugs can be a pain to get back in... And they appear to be in, but they arent.Since all this information (security codes, tacho, speed, etc, etc) is delivered by the CAN bus, leaving one of the plugs out somewhere along the chain could cause problems. My best guess anyways. Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-1007272 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 9m 29d Gender: Male Location: Aspendale, Vic. Posted 13/05/10 01:09 AM Share Posted 13/05/10 01:09 AM press menu + FM.enjoy! Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-1007275 Share on other sites More sharing options...
Fix New Member 1 Member For: 6y 1m 21d Posted 25/03/19 06:15 AM Share Posted 25/03/19 06:15 AM I came here to look for a solution but didnt find one I removed the whole thing again and made sure everything was plugged in then plugged it back to car and put the 4 plugs in bottom of it it works perfectly again now I removed to clean cd player played first song of every disk then kept ejecting disks this should work guys doesn't try again if it works happy to help. Link to comment https://www.fordxr6turbo.com/forum/topic/64654-icc-security-code-error/#findComment-1679831 Share on other sites More sharing options...
