RAP1D Member Donating Members 3,739 Member For: 18y 6m 6d Gender: Male Location: Sydney NSW Posted 31/12/09 12:02 AM Share Posted 31/12/09 12:02 AM you should look at wider rims for the back mate... all that sexhead power is wasted through 245s Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 18y 11m 27d Gender: Male Location: Melbourne Posted 31/12/09 12:46 AM Share Posted 31/12/09 12:46 AM lolI'd only get them if my car is written off and I get an FG F6 But I doubt they'll write it off Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 31/12/09 12:51 AM Share Posted 31/12/09 12:51 AM Also depends on the accual measured width of the tyre, I've had some 275/30s that have been alot wider, than other brand 275/30s on the same rim.I have Nexen 265/30 on 8.5inch rims on the front, the side walls pull in a little... and 295/30s on 9.5s on the rear, they are also pulled in a touch.I had 255 nexen's on the front. They are not a bad tire once they get warm. Not much turn in on them. And I chewed a chunk out of the side wall hitting the curbs.I replaced them with Pilots 245 on my 8.5's and kept the 275 nexens on the back on my 9.5's. Nicely balanced combo and cheap to replace the rears. 295's sat about 1cm outside the guards on my fg with the rims I have Link to comment Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 6m 6d Gender: Male Location: Sydney NSW Posted 31/12/09 02:41 AM Share Posted 31/12/09 02:41 AM Yeah they arnt comparable to Pilots, but for the $ not too bad... yeah mine copped some chunks out of the sidewalls too.I used spacers welded into the rims, with longer studs on the rear to bring the 295s out, otherwise they rubbed inside... fat look from behind! Link to comment Share on other sites More sharing options...
