GreyXR6_Turbo Member 60 Member For: 16y 2m 19d Posted 24/12/09 12:21 PM Share Posted 24/12/09 12:21 PM Gday all I recently took my BF2 turbo on a trip down to Eden, and loved it for its comfort and refinement. However, I noticed when I went to overtake a car in an overtaking lane, I applied some throttle, and the ZF went down a few gears, revving at about 3000RPM. However, it refused to drop back into the higher gears once easing off the throttle? I gave it a few seconds to get back to a cruising gear, but I had to shift it into performance mode, then into 6th gear manually... Awesome automatic, still good in every way except for this issue. The vehicle is still under warranty. Can Ford reflash the computer to fix the problem? I have also heard that having two rear tyres (these cars with the 6 speed auto) at different tread levels can muck around with the auto? Any help appreciated Cheers Link to comment Share on other sites More sharing options...
Daniel Member 299 Member For: 21y 4m 25d Gender: Male Posted 25/12/09 02:46 AM Share Posted 25/12/09 02:46 AM This sounds fairly normal to me..If you are a little enthusiastic with the throttle in any auto mode (which you obviously were is you dropped a few gears), the box will hold gears for a while after you get off the throttle thinking you are planning on having more fun any moment... this is a GREAT thing wen you are on tracks or on windy mountain roads!If you wait a bit, the box will drop back into higher gear/s; or you can blip the throttle a tiny bit after you come off and it will then begin upshifting away to 6th again.An easy way to avoid it if for some reason you do not like this is when you accelerate regardless of throttle input, ease off the throttle gently and progressively; don't just go right to 0% throttle as it will hold the gears like you mentioned.It is a smart box... Link to comment Share on other sites More sharing options...
Benji_vs Donating Members 403 Member For: 16y 6m 24d Gender: Male Location: East Suburbs Melbourne Posted 25/12/09 04:35 AM Share Posted 25/12/09 04:35 AM Your right the auto does hold the gear even after you let off after overtaking, I think that is because you take off in a spirited fashion it expects you to keep driving like that so it holds. I also notice that if you ease off progressively as mentioned above it upshifts normally.Hope that helps Link to comment Share on other sites More sharing options...
20pounds Member 180 Member For: 16y 2m 6d Gender: Male Posted 25/12/09 09:37 PM Share Posted 25/12/09 09:37 PM your right bout the tyres too. ive had the same thing happen to me when my rear tyres are getting low also when I put new rears on then the dsc starts playing games until the computer adjust itself Link to comment Share on other sites More sharing options...
Pete A Member 442 Member For: 15y 11m 28d Gender: Male Location: Castle Hill NSW Posted 26/12/09 11:41 PM Share Posted 26/12/09 11:41 PM This is normal - enjoy it! Link to comment Share on other sites More sharing options...
GreyXR6_Turbo Member 60 Member For: 16y 2m 19d Posted 30/12/09 03:24 AM Author Share Posted 30/12/09 03:24 AM Thanks for the replies lads. All I can say it is a great step up from the automatic TE magna I drive as a daily! Cheers! Link to comment Share on other sites More sharing options...
