purple beast Member 5 Member For: 14y 11m 1d Gender: Male Location: perth Posted 23/12/09 06:49 AM Share Posted 23/12/09 06:49 AM can any one help to will me where abouts I connect the signal wire for my air fuel ratio gauge connects to my pcm photos would help as this is my first turbo car Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 15y 11m 15d Posted 23/12/09 07:09 AM Share Posted 23/12/09 07:09 AM hey mate forget about wiring the afr gauge they dont work unless you get the autometer wideband gauge with the sensor,cost about 450 dollars. if you still wanna hook your gauge up use the black wire for the sensor it will not giue u the right readings that you would expect but that is the wire you use for the ba xr6 turbo Link to comment Share on other sites More sharing options...
purple beast Member 5 Member For: 14y 11m 1d Gender: Male Location: perth Posted 23/12/09 07:31 AM Author Share Posted 23/12/09 07:31 AM well how do I know if its a autometer wideband gauge just looking at it now it says pro-comp ultra lite and from auto meter its a LED one that lights up if that makes sence to you that's for your helpbtw ill show you a photo if that can tell you the right thing Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 15y 11m 15d Posted 23/12/09 07:44 AM Share Posted 23/12/09 07:44 AM the one you hav showed in the picture looks like the narrow band one, there pretty much only good for the jap cars. to be honest mate that gauge is not gonna do nothing on the xr6 turbo cars, trust me I went through this drama.your best bet would be to look up aplace which sells the wideband gauges etc (mod yourcar.com)the gauge will come with a sensor were u would hav to place on your dump pipe this mod will set you back around the 600 dollar mark, the wide band gauge will giue you the right readings jus like the tuners use. Link to comment Share on other sites More sharing options...
purple beast Member 5 Member For: 14y 11m 1d Gender: Male Location: perth Posted 23/12/09 07:54 AM Author Share Posted 23/12/09 07:54 AM I bought my gauge from them I will be having a word with them and what black wire do I conect it to bit lost when it come to the pcm thanks for the quick responce Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 15y 11m 15d Posted 23/12/09 09:07 AM Share Posted 23/12/09 09:07 AM you will see that on your dump pipe behind the turbo that there are 4 or 5 wires I cant really remember how much there is but what you hav to do is cut or moue the sleave that couers the wires with a razor blade or knife jus cut through the solid blac wire an solder your sencor wire to that. Link to comment Share on other sites More sharing options...
purple beast Member 5 Member For: 14y 11m 1d Gender: Male Location: perth Posted 24/12/09 03:08 AM Author Share Posted 24/12/09 03:08 AM hi mate I tried to connect to the black wire and nothing happens when the signal wire is disconected you can see one led light up and nothing have you got any other ideas thanks mate Link to comment Share on other sites More sharing options...
CCCC miso xr6 Donating Members 317 Member For: 15y 11m 15d Posted 24/12/09 05:28 AM Share Posted 24/12/09 05:28 AM hi mate I tried to connect to the black wire and nothing happens when the signal wire is disconected you can see one led light up and nothing have you got any other ideas thanks matewhat model is your car is it a ba or bf if its a bf you conect it to the solid grey if its a ba you connect it to the black wire, you sould see the gauge bounce up an down. Link to comment Share on other sites More sharing options...
