Matt Malone Member 4 Member For: 15y 5m 9d Gender: Male Location: brisbane Posted 22/12/09 05:41 AM Share Posted 22/12/09 05:41 AM well I changed the tune on my flash tuner the other day and seem to have lost cruise control because of it.. Im not sure if it was the changing of the tune that has dont it but I was using cruise control about 5 mins before so think it was.has the ever happened to anyone with/without tune??is there a fuse or something that could have blown causeing this?? Link to comment https://www.fordxr6turbo.com/forum/topic/64527-cruise-control-not-workin/ Share on other sites More sharing options...
tab Sucker Moderating Team 32,303 Member For: 20y 11m 26d Gender: Male Location: Brisbane Posted 22/12/09 06:43 AM Share Posted 22/12/09 06:43 AM Might be a bit left-field, but are you touching the brake at all between starting the car and turning on the cruise control...as it needs to see the brake light circuit working before it will engage.If not then I got NFI. Have you tried it on the factory tune (if possible)? Link to comment https://www.fordxr6turbo.com/forum/topic/64527-cruise-control-not-workin/#findComment-965295 Share on other sites More sharing options...
ENVY-T CNUTOX Donating Members 3,098 Member For: 22y 3m 14d Gender: Male Location: Not sure? Posted 22/12/09 06:48 AM Share Posted 22/12/09 06:48 AM Check to see if both your brake lights are working. If there is any drop in voltage the cruise turns on but will not set. Link to comment https://www.fordxr6turbo.com/forum/topic/64527-cruise-control-not-workin/#findComment-965298 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 24d Gender: Male Location: @ my laptop Posted 22/12/09 07:13 AM Share Posted 22/12/09 07:13 AM as mentioned check the obvious, fuses etc, check operation of brake lights as if they are not working it may be affected, a faulty brake light switch will also stop it from working.If that is all ok, flash the standard tune back into the car, it it now works, you may have a tune based on an incorrect processor code for your car. Link to comment https://www.fordxr6turbo.com/forum/topic/64527-cruise-control-not-workin/#findComment-965304 Share on other sites More sharing options...
Matt Malone Member 4 Member For: 15y 5m 9d Gender: Male Location: brisbane Posted 24/12/09 09:50 AM Author Share Posted 24/12/09 09:50 AM well today the horn stopped workin haha but it seems to work after a certian amount of right hand lock??? any ideas Link to comment https://www.fordxr6turbo.com/forum/topic/64527-cruise-control-not-workin/#findComment-965870 Share on other sites More sharing options...
ratter Member 6,793 Member For: 18y 10m 24d Gender: Male Location: @ my laptop Posted 24/12/09 11:02 AM Share Posted 24/12/09 11:02 AM Clock spring on the steering column, could explain all your problems Link to comment https://www.fordxr6turbo.com/forum/topic/64527-cruise-control-not-workin/#findComment-965889 Share on other sites More sharing options...
