Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 7m 15d Gender: Male Location: Zombie Birdhouse Posted 14/12/09 06:45 AM Share Posted 14/12/09 06:45 AM I'm doing a compression test tomorrow. that'll tell if it's a rod.There is no smoke, fluid leaks, smells, etc anywhere. The car drives normal. sounds like sh*t but drives normal. I'm gonna get the guys from ford to have a look and listen tomorrow, and quote me on a repair (the idea of the quote is to see how much they will charge to diagnose, and repair. What's the official verdict ? fingers crossed for ya Link to comment Share on other sites More sharing options...
mattyb Donating Members 1,097 Member For: 16y 9m 20d Gender: Male Location: Gold Coast, QLD Posted 14/12/09 11:22 AM Author Share Posted 14/12/09 11:22 AM (edited) Okay, no compression test as the dial I have doesn't reach all the way down to where the plugs are. Everyone wants to pull the motor out and have a look, and some of the shops in town have said, 'if it runs bring it down, cant be that bad!' It was tuned by Dave - Blueboost, I made no secret of having him tune the car, and it's not his fault, he did what I paid for - Pushed it to the limit. I was aware that we had the car pretty high on the power scale, I was just hoping that we didn't take it too far. Gonna put the rocker cover back on tomorrow and take it a couple of places to see what they say. Wish I was in Mackay, at least they have tuners and engine shops there. Edited 14/12/09 11:31 AM by mattyb Link to comment Share on other sites More sharing options...
Buf-Phoon loitering with intent Lifetime Members 13,318 Member For: 21y 7m 15d Gender: Male Location: Zombie Birdhouse Posted 14/12/09 12:01 PM Share Posted 14/12/09 12:01 PM mate , as said you can't blame Dave. Just hope it's not a rod. Good luck buddy Keep us posted as we can all learn. Well some of us Link to comment Share on other sites More sharing options...
NFORCD Force Fed Fords Member 209 Member For: 16y 5m 23d Gender: Male Location: Melbourne Posted 14/12/09 01:01 PM Share Posted 14/12/09 01:01 PM You do say it comes from the front somewhere right... It clearly doesn't sound right mate and even though you say it ddrives fine and such I wouldn't take the risk of driving it till this problem is solved... By any chance could it be your tensioner on the belt? Just an idea mate. Put a screw driver on that or on the bearings there buddy and try to hear for the sound... Let us know how you go, goodluck Link to comment Share on other sites More sharing options...
mattyb Donating Members 1,097 Member For: 16y 9m 20d Gender: Male Location: Gold Coast, QLD Posted 15/12/09 10:58 AM Author Share Posted 15/12/09 10:58 AM (edited) So here is where I'm at...Compression test complete, and well, things aren't looking too good. But we still have to do the leak test yet.POT #1 - 195 PSIPOT #2 - 195 PSIPOT #3 - 130 PSIPOT #4 - 165 PSIPOT #5 - 195 PSIPOT #6 - 175 PSIGoing to check that the vac line to the fuel reg is connected still, as one came loose on a car I know of and caused it to run lean and resulted in almost identical pressure readings and a bent #3 rod. We are going to inspect a few other things while I'm at it but once we 100% confirm a bent rod with the leak test it looks like I'll be stripping it down and rebuilding the motor. As it stands I'm pretty broke, so ill be looking at maybe F6 pistons and rods with a billet oil pump, or maybe, F6 pistons with a set of spool rods, and a billet oil pump, but $$$$ will be the key factor here.If anyone has any of the above mentioned parts for sale or where I can get them at dirt cheap prices... let me know. Edited 15/12/09 11:06 AM by mattyb Link to comment Share on other sites More sharing options...
blueboost Member 1,204 Member For: 20y 10m 7d Gender: Male Location: Mackay NorthQueensland Posted 15/12/09 11:29 AM Share Posted 15/12/09 11:29 AM Hey Matt, this is the time when I hate tunning cars,got to change one thing you said Matt, you did not ask to push it right to the limit, but we had not realy pushed it that far either, because of the fact you are in land, where bad fuel can end up getting into cars, we had almost enough Knock retard to pull the timing back to nearly zero, this power should not have hurt this motor, I hope we end up finding what has hurt it, I listened to the noise you sent me, a bit strange,very tinny, and to me almost sounds at a faster beat then the idle rpm. got to go to work now, keep in touch Matt. David Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 8m 17d Gender: Male Location: Aspendale, Vic. Posted 15/12/09 11:35 AM Share Posted 15/12/09 11:35 AM cracked piston ring ?? ;( Link to comment Share on other sites More sharing options...
RUS531 RUS531 Donating Members 410 Member For: 18y 7m 14d Gender: Male Location: Emerald QLD Posted 16/12/09 03:25 AM Share Posted 16/12/09 03:25 AM hey matty,Sorry to hear about your dramas dude... nasty sound too. A thought for parts... maybe you could give brad at atomic a call and see if he has some good condition second hand F6 pistons and rods he could sell you New ones would be the go though, for piece of mind.Keep us in the loop.Cam Link to comment Share on other sites More sharing options...
bertis Member 30 Member For: 15y 7m 27d Posted 04/01/10 11:00 PM Share Posted 04/01/10 11:00 PM that's a strange sound. How high is your idle. I've seen a few engines knock and they seem to knock at half the speed of this 1..... Maybe your pressure reg vac line failed and caused it to lean out to much? Link to comment Share on other sites More sharing options...
straughsberry Donating Members 1,846 Member For: 17y 7m 16d Gender: Male Location: Broady, Melbourne Posted 05/01/10 03:13 AM Share Posted 05/01/10 03:13 AM Sounds too "thick" to be an exhaust leak and it I think those compression figures tell the story. When I bent a rod, and I mean bent, it took a chunk out of the block at the bottom of the bore where the rod was giving the block a hip-and-shoulder. The engine still ran but it was seriously sick as you'd imagine.Sorry to hear mate. If you need pistons and/or rods and you're thinking Mahle and Argo let me know. I've got some at a very good price. Especially the pistons. I won't mention a price here but PM me and I'll let you know. Link to comment Share on other sites More sharing options...
