  • Member For: 16y 6d
  On 02/03/2016 at 2:56 PM, PTR_NITRO_FG said:
Nice one. How long did it take you to do the swap over?
Did your original ICC have dual zone? Cause apparently Ford said you have to stick to the same type cause near impossible to make a dualzone work on a single zone car?
Its definitely one of those 'one day' mods for me
Hey mate the change over is literally a 10 min job. Pop the top plastic cover off and pull out the tissue box holder then there's two screws at the top and four bolts at the bottom. A couple of plugs at the top and one at the bottom. Slide the old one out and plug in the patch harness and do the reverse to fit the new one.
My car had the dual climate control already so everything works perfectly.
Basically my cat is exactly the same as before but I now have a larger touch screen and blue tooth streaming from my phone. All nice and tidy.
Sent from my SM-G920I using Tapatalk
  • Member For: 10y 5m 14d
  On 06/03/2016 at 5:48 AM, wagnman said:
Its not a cheap conversion. With the patch harness and mods to make the ac and external temp show correct etc its around $1300
Expand
Thanks, what mods are required for ac & temp sensor?
