Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 10m 2d Gender: Male Location: Greenvale, Victoria Posted 07/12/09 01:22 PM Author Share Posted 07/12/09 01:22 PM Oh SMicky. Your just a laugh you is.If it was a crappadore I'd agree (although any car these days tends to fall apart)Seriously though, I complained to my dealer before and they said it was the diff bush. So I have found this is a common fault. So they changed it and guess what? Problem was still there.So stuffed if I know. It was in my previous BA as well. Must be just me. Link to comment Share on other sites More sharing options...
xtremerus Member 59 Member For: 15y 10m 16d Location: North-West NSW Posted 10/12/09 08:48 AM Share Posted 10/12/09 08:48 AM 2 problems I had1) ball joint on the control arm (or whatever it's called) http://www.trueblueford.com/images/BA_IRS1_l45.jpg the yellow thing on the left of the photo mounted between the control blade and the shock. Keep in mind that you can't tell it's f*cked when the wheels are hanging in the air, you got to raise the car by jacking it under the lower control arms so the wheel spring is compressed but the wheel is in the air, if you know what I mean.I'm betting that one. Just had that replaced at 95000km on the car. Link to comment Share on other sites More sharing options...
Gymy Member 18 Member For: 16y 9m 7d Gender: Male Location: Watsonia, VIC Posted 14/12/09 06:21 AM Share Posted 14/12/09 06:21 AM You're car is lower than Standard Yes? I had the same problem, the car was hitting the Bump Stops. I cut the Bump stops about an Inch and problem solved. Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 10m 2d Gender: Male Location: Greenvale, Victoria Posted 15/12/09 01:53 PM Author Share Posted 15/12/09 01:53 PM Actually Gymy, no the car isn't lowered at all. Its getting worse though. It used to be every now and then but now its nearly every bump. I guess if I let it go the diff will just fall out and it'll be a case of "Theres ya problem" lol. Link to comment Share on other sites More sharing options...
sexual harrassment panda I see a red door and I want to paint it black Donating Members 5,919 Member For: 15y 4m 14d Gender: Male Location: Far north queensland Posted 16/12/09 08:11 PM Share Posted 16/12/09 08:11 PM my car does this too, let me know any updates. Link to comment Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 17y 10m 23d Gender: Male Location: Sydney Posted 16/12/09 11:00 PM Share Posted 16/12/09 11:00 PM Diff bush would not make sounds over bumps. It would mainly do it when accelerating and decelerating. Take it to a suspension shop and get them to check the rest of the bushes in the back, especially the ball joints. Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 10m 2d Gender: Male Location: Greenvale, Victoria Posted 04/01/10 11:12 AM Author Share Posted 04/01/10 11:12 AM I'd take it to pedders but they wanna sell you their stuff.But this is the thing that sh*ts me. Pedders tell me lower ball joints are worn. SoI book it in under warranty at Ford and they tell me they "are within tolerances". But why should I pay to fix something that should be covered by warranty??I guess the answer is to stuff em and just put better components in despite them.3 visits for service /warranty and they STILL can't tell me what the bang is. Hopeless. Link to comment Share on other sites More sharing options...
Guest XR09 Guests Posted 05/01/10 04:12 AM Share Posted 05/01/10 04:12 AM 1. Get a written diagnostic/quote from Peddars explaining what they think needs replacing. Or even from your local NRMA/RACQ.2. I doubt any OEM bush is still at 70% of it's natural resistance after 55,ooo k's.I replaced all the bushes that I could on mine at 15,000 when I was in there replacing the dampers and springs.Get a mate to drive or sit in the back and try and isolate it more. Take out all your carpet and shoite in the boot when you do.Mine will clunk when the spring tops the damper over bumps at low speeds as I run a low rebound resistance on the road. So is it a topping noise or a bottoming one ???Are your dampers and springs matched ? Link to comment Share on other sites More sharing options...
Rudiger All round good guy! Lifetime Members 1,122 Member For: 16y 10m 2d Gender: Male Location: Greenvale, Victoria Posted 05/01/10 06:57 AM Author Share Posted 05/01/10 06:57 AM Thanks for your input.Its really hard to say if its bottoming ot topping. But Ill describe it. Say I hit a crack in the road from 15kph to 60 kph, doesnt matter. The front goes over the crach with a nice wump, then the back wheel or wheels it and its like BANG.Same if I am reversing out of the drive. Sometimes the back will go bang while the front just make the soft wump sound.Now as of dampers, I wouldnt know, although the noise was there before.I just got king springs (non lowered) and bilstein shocks from Perfermance Suspeniosn in Sydney (Penrith) I didnt want adjustable as I would play too much.The pedders idea sounds good and I would love to change all the bushes but would know what to get. I guess I ll message Senna_t and get a list.But does my description help? Link to comment Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 7m 22d Gender: Male Location: Aspendale, Vic. Posted 05/01/10 07:16 AM Share Posted 05/01/10 07:16 AM question, did u get them to install the shocks and springs? or did you just buy from there and do a home job? did the car have stock springs/suspension before these where installed? Link to comment Share on other sites More sharing options...
