FAST-XR EVIL T Member 259 Member For: 16y 1m 26d Gender: Male Location: Liverpool NSW Posted 26/11/09 01:34 AM Share Posted 26/11/09 01:34 AM Ok, I have a crossover replacement pipe, and I have a temporary dose pipe setup until the cooler kit goes on. im running the 8psi generic tune...I have an the oil breather line connected to the dose pipe (its almost 2m long as it runs around the back of the engine bay under the coolant tank and into the dose pipe, im not sure if the length is a problem...)but yesterday I felt the car wasnt feeling right, I looked under the bonnet and saw oil all over the intake manifold, the dipstick popped up and allowed oil to spray everywhere...Why has this happened? and how can I stop it happening again?I was thinking of attaching an extension spring to hold the dipstick down, but id like to fix the cause before I just put something there to force the dipstick in place...thanks Link to comment Share on other sites More sharing options...
ms700 Moderating Team 10,170 Member For: 22y 4d Gender: Male Location: Sydney Posted 26/11/09 01:40 AM Share Posted 26/11/09 01:40 AM Id say its a breather issue.Somehow the sump is getting pressurised, and the oil is spraying out the dipstick hole. Link to comment Share on other sites More sharing options...
senna_T Forged Member Lifetime Members 15,818 Member For: 17y 11m 28d Gender: Male Location: SW Sydney Posted 26/11/09 01:59 AM Share Posted 26/11/09 01:59 AM make sure the breather line isn't blocked or kinked - I have a similar setup with no probs... Link to comment Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 7m 16d Gender: Male Location: Earth Posted 26/11/09 02:03 AM Share Posted 26/11/09 02:03 AM Also make sure the oring seal is on the dipstick.This will create some grip and sealing in the tube when it is installed. Link to comment Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 1m 26d Gender: Male Location: Liverpool NSW Posted 26/11/09 02:23 AM Author Share Posted 26/11/09 02:23 AM I have checked the hose for kinks, and the oring is still intact, I doubt the breather is blocked as its only been on for a few days...but ill have a look into it anywaydoes it matter what size breather line I have?im using an 8mm ID fuel line hose, I have it slipped over the existing breather line which is about 9mm OD. Its tight! Link to comment Share on other sites More sharing options...
FAST-XR EVIL T Member 259 Member For: 16y 1m 26d Gender: Male Location: Liverpool NSW Posted 26/11/09 03:47 AM Author Share Posted 26/11/09 03:47 AM I think I know what the problem is...the hose dips down a bit in one place, im thinking that oil has settled in this part of the line and filled up, stopping air from passing.... ill re-route the hose so that it drains properly all the way to the intake, and ill see what happens... Link to comment Share on other sites More sharing options...
kissy Member 132 Member For: 17y 10m 21d Gender: Male Location: S.E. Melbourne Posted 26/11/09 05:42 AM Share Posted 26/11/09 05:42 AM I’d say because you have your breather hooked up to the dose pipe, when you back off the throttle the turbo pressurises the engine. I’d guess and say that your PCV (Positive Crankcase Ventilation) valve is stuffed… That’s my thoughts any way! Link to comment Share on other sites More sharing options...
mic Donating Members 1,725 Member For: 17y 17d Gender: Male Posted 26/11/09 06:46 AM Share Posted 26/11/09 06:46 AM when I drove out to see mal wood my dipstick done this also. I didnt flog it at all and the only thing it could have been was the bumpy road knocking it out. when I got there it was actually back in its place, they are loose as in fitment. I just zipped tied mine in Link to comment Share on other sites More sharing options...
xhxrsix Member 174 Member For: 18y 2m 28d Gender: Male Location: Melbourne Posted 26/11/09 09:58 AM Share Posted 26/11/09 09:58 AM how many k's has it done? sure its not excessive blowby pressuring the engine? Link to comment Share on other sites More sharing options...
Guest EGOXRT Guests Posted 26/11/09 10:02 AM Share Posted 26/11/09 10:02 AM Cactus. Sounds like major blow by. Link to comment Share on other sites More sharing options...
