Ninka Donating Members 1,850 Member For: 22y 1m 12d Gender: Male Location: Perth, WA Posted 16/01/03 02:33 PM Share Posted 16/01/03 02:33 PM Just thougt I would share some of my experiences with you guys playing with the idea of increasing boost on the XR6 Turbo.I set up a combination of Pressure Relief Valve, Pressure Regulator and a temporary boost gauge to "play around" a little, while focusing on staying within safe parameters, and not doing anything that might over stress the engine or transmissionIf the factory boost control valve is bypassed the ECU will completely screw up the gear change pattern in the automatic so that in PERF it will constantly choose 4th gear, and when choosing 3rd in sequential mode, same thing. Kickdown is very reluctant, and overall there does not appear to be any gains! Not sure how a manual will react!When adding a pressure controller after the boost control valve, and increasing boost very moderately (less than2 psi) there is a slight power increase during initial acceleration, but this is capped by the ECU once full boost is reached (probably by retarding ignition) so that the end result is actually a slower car.Throttle response was improved slightly, and the turbo came on a little more quickly, so it could appear as if the factory setting opens the wastegate very gradually. I will play around a little further with a pressure relief valve set at say 4-5 psi, which would mean that the wastegate is prevented from opening until the boost reaches 4-5 psi or whatever I measure factory settings to be.I have done this sort of thing before in Europe, and in fact I converted a Ford 2000 EFI to turbo some years ago, so I guess I have some experience in the field, but I will once again repeat my warning to the inexperienced DON'T PLAY - YOU MAY PAY!Overall I am happy with the performance of the vehicle, and I'm not looking to "boost its brain out", just a bit curious as to how the thing works. Link to comment Share on other sites More sharing options...
Guest esky Guests Posted 16/01/03 08:53 PM Share Posted 16/01/03 08:53 PM ninka,Interesting results. I have seen very simular response with the Barra240 when playing with boost options. The dyno outputs don't lie. This is one hard nut to crack. Anyway I'm happy with the power of the car as is. It's not the fastest thing on the road, but street presence is priceless. Esky Link to comment Share on other sites More sharing options...
scott52 Member 188 Member For: 22y 1m 11d Gender: Male Location: Perth, W.A. Posted 19/01/03 09:59 AM Share Posted 19/01/03 09:59 AM Just thougt I would share some of my experiences with you guys playing with the idea of increasing boost on the XR6 Turbo.I set up a combination of Pressure Relief Valve, Pressure Regulator and a temporary boost gauge to "play around" a little, while focusing on staying within safe parameters, and not doing anything that might over stress the engine or transmissionIf the factory boost control valve is bypassed the ECU will completely screw up the gear change pattern in the automatic so that in PERF it will constantly choose 4th gear, and when choosing 3rd in sequential mode, same thing. Kickdown is very reluctant, and overall there does not appear to be any gains! Not sure how a manual will react!When adding a pressure controller after the boost control valve, and increasing boost very moderately (less than2 psi) there is a slight power increase during initial acceleration, but this is capped by the ECU once full boost is reached (probably by retarding ignition) so that the end result is actually a slower car.Throttle response was improved slightly, and the turbo came on a little more quickly, so it could appear as if the factory setting opens the wastegate very gradually. I will play around a little further with a pressure relief valve set at say 4-5 psi, which would mean that the wastegate is prevented from opening until the boost reaches 4-5 psi or whatever I measure factory settings to be.I have done this sort of thing before in Europe, and in fact I converted a Ford 2000 EFI to turbo some years ago, so I guess I have some experience in the field, but I will once again repeat my warning to the inexperienced DON'T PLAY - YOU MAY PAY!Overall I am happy with the performance of the vehicle, and I'm not looking to "boost its brain out", just a bit curious as to how the thing works. ninka, if you've seen some of my previous posts I to have been tinkering with boost control - just to try to understand how this thing works. I'm not interested in turning the thing into a grenade either! I wouldn't mind comparing notes and have a look at you rexperiments. Link to comment Share on other sites More sharing options...
Fat-Tony Member 5,364 Member For: 18y 10m 14d Posted 01/08/08 02:34 PM Share Posted 01/08/08 02:34 PM So how did all that boost control work pan out for you? Link to comment Share on other sites More sharing options...
Guest dico2020 Guests Posted 01/08/08 02:48 PM Share Posted 01/08/08 02:48 PM ummmm ok Link to comment Share on other sites More sharing options...
SheldonXR6T Member 2 Member For: 16y 5m 25d Posted 10/08/08 05:48 AM Share Posted 10/08/08 05:48 AM I wouldnt play around with just boost without having the engine management corrected to suit otherwise like ppl have said BANG!!! Link to comment Share on other sites More sharing options...
seventytwo Still have a turbo, it's just on a diesel. Lifetime Members 5,368 Member For: 19y 6m 28d Gender: Male Location: The 8th Dimension Posted 10/08/08 05:55 AM Share Posted 10/08/08 05:55 AM Hi sheldon yes you are right, but the original post was made in 2002 and we have learnt a lot since then and I am sure Ninka has to seeing as though he is one of the pioneers in T modification. Link to comment Share on other sites More sharing options...
