sash Love the Ride.... Member 236 Member For: 21y 8m 22d Location: Roleystone, WA Posted 16/12/03 08:41 AM Share Posted 16/12/03 08:41 AM Aaron, do you have any suggestions on how and what to use for the display. I'm trying to upgrade my standard to premium, so if there are better solutions out there, I would love to hear them...CheersSash Link to comment Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 2m 23d Location: Canberra - ACT Posted 16/12/03 10:14 AM Share Posted 16/12/03 10:14 AM If you have standard sound and depending on what you want from a system you best bet would be to mount a 'in dash' fold out display down in the tissue holder area and drive it with the visual gear of your choice, feeding the Line out audio of such a thing into the AUX input of the stock sound system...If I'm reading your intentions correctly you're more after DVD/in car Nav than anything else?A. Link to comment Share on other sites More sharing options...
Mitchy_G Umm... Member 176 Member For: 21y 6m 2d Location: North Lake Macquarie NSW Posted 16/12/03 10:48 AM Share Posted 16/12/03 10:48 AM I saw an ICC in action with dvd and sat nav, OH MY GOD, im dying, I check this page like every couple of hours in hope.Aaron what type of technology do we need for IR controls? can the IR port near the ICC be used to control several devices? Like switching inputs and controlling DVD player? Link to comment Share on other sites More sharing options...
aaronmihe Upstanding Member Member 759 Member For: 21y 2m 23d Location: Canberra - ACT Posted 16/12/03 11:35 AM Share Posted 16/12/03 11:35 AM Mitchy_G I've had a laptop plugged into the ICC as a 'plaything' it's a very nice quality display and really should shine when I move forward witht he Xbox project early next year (after we get back from our much needed holidays)The IR sensor can feed multiple devices, it's a fully buffered output .. very handy indeed.A. Link to comment Share on other sites More sharing options...
Mitchy_G Umm... Member 176 Member For: 21y 6m 2d Location: North Lake Macquarie NSW Posted 20/12/03 02:57 AM Share Posted 20/12/03 02:57 AM YAY, I discovered the tutorial on fordmods and will be starting it 2moro, I hope.Is there anybody who can help me with the procedure to acces the video connector? (like which screws to undo on the dash) I dont really wanna undo any old screw Aaron, is the reason why you reccomended SCART because it keeps red signal, blue signal.... etc separate so it is easily plugged into the ICC, unlike a single RCA plug? Thanks Link to comment Share on other sites More sharing options...
Mitchy_G Umm... Member 176 Member For: 21y 6m 2d Location: North Lake Macquarie NSW Posted 20/12/03 07:16 AM Share Posted 20/12/03 07:16 AM OKIve got the dash apart thanks to saleen1, now I just need to get the connector.Im thinking it is the one sitting to the left of centre and its only just above the dash trim? It is white and it sits open end facing to the front of the car?I cant seem to get the connector loose?Any Help?Mitch Link to comment Share on other sites More sharing options...
Mitchy_G Umm... Member 176 Member For: 21y 6m 2d Location: North Lake Macquarie NSW Posted 20/12/03 07:42 AM Share Posted 20/12/03 07:42 AM OK ive worked out that getting the connector loose is not too big of a deal, cant wait for 2moro Link to comment Share on other sites More sharing options...
Blueprint Stunner Member 25 Member For: 21y 11m 24d Posted 10/01/04 02:09 AM Share Posted 10/01/04 02:09 AM Hi guys, im still a little confused, is the xbox mod fully workable at this stage? I can only seem to find detailed info on how to hook up a pc to the icc, but im more interested in knowing if anybody has an xbox mod that is working on the icc??? if so, can someone tell me in detail what I need to do to get this working? thanks!!! Link to comment Share on other sites More sharing options...
Mitchy_G Umm... Member 176 Member For: 21y 6m 2d Location: North Lake Macquarie NSW Posted 10/01/04 09:16 AM Share Posted 10/01/04 09:16 AM Stunner, Ive done a fairbit of research on xbox. Not having the system myself makes it quite hard to make plans on what the next step will be. The xbox will need to be NTSC (60hz refresh), I think a mod chip can give you the options of switching between the two (PAL and NTSC).A SCART cable used with the xbox will keep each of the specified signals separated (e.g. red, blue, green, h sync, etc) instead of combining them into 3 RCA plugs, which wont work.But I cant say much more, I need the system. I also have conflicting information and I need the system to set things straight. If I get it going ill put on a HOW TO.Mitch Link to comment Share on other sites More sharing options...
Blueprint Stunner Member 25 Member For: 21y 11m 24d Posted 10/01/04 11:03 AM Share Posted 10/01/04 11:03 AM Thanks Mitchy_G, this helps me a little, I just need to clarify something though. Are you saying that (aside from the audio connector) all I need is a scart cable (scart on both ends?) to connect the video part up of the icc from the xbox? also if it's not too much trouble do you have a photo of the cable I need, or any other components? if its not too much trouble. Link to comment Share on other sites More sharing options...
