Ninka Donating Members 1,850 Member For: 22y 2m 9d Gender: Male Location: Perth, WA Posted 16/01/03 02:05 PM Share Posted 16/01/03 02:05 PM Have any of you noticed how the turbo keeps spinning after the engine is turned off, even after adequate idling.You should notice it as a gradually diminishing slight sound from the engine bay for about 15 seconds after the engine stops 1 Link to comment Share on other sites More sharing options...
Lightning Member 335 Member For: 22y 1m 17d Location: Perth, Western Australia Posted 16/01/03 02:09 PM Share Posted 16/01/03 02:09 PM Have any of you noticed how the turbo keeps spinning after the engine is turned off, even after adequate idling.You should notice it as a gradually diminishing slight sound from the engine bay for about 15 seconds after the engine stops Check out http://www.fordxr6turbo.com/forum/index.ph...ct=ST&f=9&t=473 if you haven't already. Sounds like the answer to my question regarding a turbo timer Simon.... Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 2m 9d Gender: Male Location: Perth, WA Posted 16/01/03 02:40 PM Author Share Posted 16/01/03 02:40 PM I don't think a turbo timer is necessary, but only that the Garrett GT40 Turbo spins so easily due to the ball bearing set-up, that even idling is enough to spin the turbo at a few hundred RPM (have in fact confirmed this by removing the plastic intake tube and look at the compressor rotor - it does spin at idle), and this causes the continued spinning after the engine is turned off! Link to comment Share on other sites More sharing options...
physh Member 248 Member For: 22y 4m 21d Location: Canberra Posted 16/01/03 10:11 PM Share Posted 16/01/03 10:11 PM Yeah, I've noticed the sound as well.At first thought it was my A/C compressed air escaping, then realised it was a little different.Makes sense though, you don't want to just stop something like the compressor wheel that's spinning, much better to let it run its momentum down by itself.Probably helps keep the cooling system going as well - bearing still turning, if it's this thermosyphon system, the cooling will GET to the bearings, but the bearings have to be moving to get the heat transfer properly.I think... Link to comment Share on other sites More sharing options...
Guest esky Guests Posted 17/01/03 07:22 AM Share Posted 17/01/03 07:22 AM Have any of you noticed how the turbo keeps spinning after the engine is turned off, even after adequate idling.You should notice it as a gradually diminishing slight sound from the engine bay for about 15 seconds after the engine stops Dude this is a good thing . I means your turbo is in relatively good condition.All BB turbos will do this. Link to comment Share on other sites More sharing options...
Guest harasn Guests Posted 17/01/03 07:57 AM Share Posted 17/01/03 07:57 AM you guys sure its not the restriction in the AC pipe at the passenger side under the bonnet? You shouldn't here the turbo spinning!!!! Link to comment Share on other sites More sharing options...
Mondie Firm Member Donating Members 2,924 Member For: 22y 4m 3d Location: Adelaide Hills Posted 17/01/03 09:21 AM Share Posted 17/01/03 09:21 AM you guys sure its not the restriction in the AC pipe at the passenger side under the bonnet? You shouldn't here the turbo spinning!!!! l've noticed this too, its definetely the turbo spinning down. Link to comment Share on other sites More sharing options...
Ninka Donating Members 1,850 Member For: 22y 2m 9d Gender: Male Location: Perth, WA Posted 17/01/03 11:52 AM Author Share Posted 17/01/03 11:52 AM you guys sure its not the restriction in the AC pipe at the passenger side under the bonnet? You shouldn't here the turbo spinning!!!! I have checked this out visually by removing the intake pipe, and yes it is definitely the turbo spinning.I guess that with Bal Bearings it spins so easily that the inertia is enough to keep it spinning for some seconds after the engine is turned off! Link to comment Share on other sites More sharing options...
Guest esky Guests Posted 17/01/03 01:31 PM Share Posted 17/01/03 01:31 PM You shouldn't here the turbo spinning!!!! Why? Link to comment Share on other sites More sharing options...
Guest SVO347 Guests Posted 20/01/03 10:08 AM Share Posted 20/01/03 10:08 AM BB turbos are pretty much meant to be silent, the only thing you should hear from them is the whinning turbine as boost increases Link to comment Share on other sites More sharing options...
