ducatijb Lifetime Members 3,448 Member For: 21y 9m 30d Gender: Male Location: sydney Posted 22/09/03 11:51 PM Share Posted 22/09/03 11:51 PM Facts and figures on BMW's F1 engineMind-boggling specs & information on the P83 [22/09/03 - 14:58]BMW engine at work !t packs more than 900 bhp, weighs less than 90 kilograms and has a maximum engine speed of 19,200 rpm. The BMW P83 engine with which the BMW WilliamsF1 Team is pitching for the 2003 Formula One World Championship title will be put out to pasture after the final race – the Japanese Grand Prix – in three weeks’ time.Up to now, no more than broad skeleton data on this power pack from the Munich Formula One factory have been released. Ahead of the last two races of the season in Indianapolis (28 September) and Suzuka (12 October), its profile is now fleshed out.Who would have guessed, for example, that 1,950 CAD drawings were made for this engine? Printed out and laid end to end, they would cover a distance of 1.3 kilometres.Facts and figures:Output of the BMW P83 is over 900 bhp.Maximum engine speed is 19,200 rpm.In a race, engine speed is limited to 19,000 rpm.Idle speed is 4,000 rpm.The engine weighs less than 90 kilograms.It completes a distance of 500 kilometres before undergoing revision.Total production of the BMW P83 is 200 units, ten of which the team takes to each race.Before being phased out the engine will have received 1,388 upgrade modifications.It comprises around 5,000 individual components, 1,000 of them different.The air intake volume is 1,995 cubic metres per hour.Maximum piston acceleration is 10,000g.Piston speed peaks at 40 metres per second and averages 25 metres per second.Exhaust temperatures of up to 950 degrees are reached.Maximum air temperature in the pneumatic system is 250 degrees.The ultra-high-speed 130R turn at Suzuka with its lateral load of 4g poses the greatest challenge to the oil system.The BMW P83 endured the highest full-throttle proportion on the Monza circuit at 73 per cent per lap.At the Monaco Grand Prix, the transmission and engine have to withstand an average 3,100 gear changes.The engine block and cylinder head are made of cast aluminium and are manufactured at the BMW Formula One foundry in Landshut using a special thin-wall casting method.BMW Munich handles, among other things the manufacture of the crankshaft (steel), camshaft (case-hardened steel) and camshaft covers, as well as processing of the cylinder head and crankcase. The oil system and engine electronics also stem from BMW Munich.BMW 83 engine timeline from concept to culmination:Concept: November and December 2001Design: January through May 2002Model construction at the BMW foundry in Landshut: March through May 2002Components manufacture: April through July 2002Initial assembly: July 2002First bench test: 31 July 2002Test phase development stage 1: August 2002 through January 2003First deployment in car: 18 September 2002Development to race readiness: October 2002 to mid-February 2003Further development: mid-February to season’s final in October 2003In the meantime the test phase for the BMW P84 engine was launched. Following successful bench tests, it was already being tested on the track in its 2004 season specification at Monza on 4 September 2003. Link to comment Share on other sites More sharing options...
Cobra potty trained Lifetime Members 1,938 Member For: 21y 9m 8d Gender: Male Posted 23/09/03 12:33 AM Share Posted 23/09/03 12:33 AM Link to comment Share on other sites More sharing options...
Macktheknife Xtreme Xalted Member Donating Members 3,112 Member For: 21y 8m 28d Gender: Male Location: BrisVegas Posted 23/09/03 12:47 AM Share Posted 23/09/03 12:47 AM Yes but can it tow a boat? Link to comment Share on other sites More sharing options...
Trumpy What's happening? Lifetime Members 1,605 Member For: 22y 1m 30d Gender: Male Location: Steel City, NSW Posted 23/09/03 01:11 AM Share Posted 23/09/03 01:11 AM It still amazes me that these engines hang together as long as they do. Piston speeds of 40m/second! Amazing technology.Shows what you can achieve if you throw lots of money at a problem. Link to comment Share on other sites More sharing options...
Ford_Power Member 798 Member For: 21y 10m 2d Posted 23/09/03 07:26 AM Share Posted 23/09/03 07:26 AM Pure class. You can see the technology behind F1 which is why it is the pinnacle of motorsport. Link to comment Share on other sites More sharing options...
SJW Member 122 Member For: 21y 5m 10d Location: Brisbane QLD Posted 23/09/03 08:49 AM Share Posted 23/09/03 08:49 AM it reminds me of the space shuttle quote.Your sitting on a big tank of rocket fuel joined by two other booster rockets which are basically fuel tanks we light with 30,000 moving parts all made by the lowest bidder. Do you feel safe ? Link to comment Share on other sites More sharing options...
Venom XR6 Member 1,460 Member For: 21y 9m 7d Location: Geelong Victoria Posted 23/09/03 09:50 AM Share Posted 23/09/03 09:50 AM You mention there that the engine has camshafts. I was under the impression that the valves are opened and closed pneumatically. ie. it has no cams, rockers or lifters. I thought that was the reason they could rev so high without breaking the valve gear. Does anyone know if this is true or not. Link to comment Share on other sites More sharing options...
ducatijb Lifetime Members 3,448 Member For: 21y 9m 30d Gender: Male Location: sydney Posted 23/09/03 08:34 PM Author Share Posted 23/09/03 08:34 PM I think only Cosworth are using that system in the Jags at present but I'm not totally sure Link to comment Share on other sites More sharing options...
FPR 40T Member 11 Member For: 21y 4m 22d Posted 24/09/03 09:49 AM Share Posted 24/09/03 09:49 AM I don't know of any F1 engines that use pneumatically operated valves currently, I thought alternative methods of valve operation were still being researched/refined.I also thought the leading theory was to use electromagetically operated valves. Link to comment Share on other sites More sharing options...
tongueboy Member 457 Member For: 21y 10m 3d Gender: Male Location: Tamworth, Armidale NSW Posted 24/09/03 10:12 AM Share Posted 24/09/03 10:12 AM not your average mower donk! Link to comment Share on other sites More sharing options...
