  • Member For: 16y 1m 1d
When I connect my Capa flash tuner and check the fault codes, a code U0100 come up.
My car has a custom tune, different injectors, cooler, cat and fuel pump.
Can anyone tell me :- What this means
How it affects my car
How to fix it.
https://www.fordxr6turbo.com/forum/topic/63577-fault-code-u0100/
  • Here since the start...
  • Member For: 22y 20d
It means lost communication with the PCM.
Just clear it. If you're car is functions as normal then it doesn't mean much.
I did clear it but it keeps coming back. My auto could be acting funny on take off. Sometimes is feels like it has a hi stall but other times the auto works normal. Could the fault code be related.
  • Member For: 15y 9m 28d
I had the same problem with mine after using a CAPA flash (X3)unit.
The Capa unit will not clear that code as its with the auto tran module, not the engine ECU.
I have a Scan Tool which checks, erases and lists ALL codes as well veiwing live data.
If your in the Eastern Suburbs of Melb. I can erase the code for you no problem.
Cheers Peter
0418 338 005
Edited by Peter J
  • 2 months later...
  • Member For: 17y 3m 11d
U2514 VEHICLE SPEED SIGNAL MISSING OR INCORRECT
Ahhh.. Check your ABS wires, speed sensors. I`ve heard guys say its the battery on its way out that causes it.
Occaisonally I`ll get some of the reported symptoms of this, my ABS and T/C lights come on. I just turn the car off, and hold my tongue in my mouth just right when I turn it back on and its all good.
My Battery is new. However the car sits all week, only driven on weekends.
  • Member For: 15y 10m 5d
thanks alot mate I think you hit the nail on the head because the day before my speedo stopped working all of a sudden.. then I fidled around wif a few things an it started working so I think its must have something to do with that thanks very much for your help
