IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 13d Gender: Male Location: OZ Posted 14/02/12 02:39 PM Share Posted 14/02/12 02:39 PM Ford are paper, aeromotive do a 40micron stainless and Magnafuel do a 25micron stainless. I dont have the experience to comment, but just throwing it put there for $h1ts and giggles Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/19/#findComment-1196305 Share on other sites More sharing options...
rednose RNS10S Donating Members 2,229 Member For: 18y 10m 4d Gender: Male Posted 14/02/12 09:18 PM Share Posted 14/02/12 09:18 PM (edited) I'm using paper but change it every 15,000. Only run eflex but will inspect the filter after I change it. Am I looking for swelling of the paper? Edited 14/02/12 09:18 PM by rednose Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/19/#findComment-1196349 Share on other sites More sharing options...
Headsex Donating Members 2,528 Member For: 19y 10m 10d Gender: Male Location: Melb Posted 14/02/12 10:37 PM Share Posted 14/02/12 10:37 PM On 14/02/2012 at 6:14 AM, BAturb said: are these clamps not rated for EFI aplications?The Tridon EFI part stainless perforated band clamp range provides superior design and proven reliability.Manufactured in Australia, the flexible stainless steel perforated band has an extended tang to cover the perforations and prevent hose damage on soft rubber hoses. Ideally suited for use on fuel and vacuum lines.If they have extended tag, then yes, it should be fine, however still not the solution I would use.These on the left are better..However, still not my solution..This is more like what I would use. OEM Spec.. Oems use these for a reason.Kevin has something similar on his surge tanks, Still need pliers to lock them, but you are able to remove them. I can't seem to find anything on the internet about them.. Not really sure what their called to be honest..Kev, chime in with what they are called? Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/19/#findComment-1196367 Share on other sites More sharing options...
Ross Bille Member 22 Member For: 13y 3m 26d Gender: Male Posted 02/05/12 12:14 PM Share Posted 02/05/12 12:14 PM To the people who have made their own or had one made up,What size fittings did yous use?and what type? Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/19/#findComment-1230832 Share on other sites More sharing options...
