1600dave Donating Members 872 Member For: 14y 3m 5d Posted 14/02/12 06:11 AM Share Posted 14/02/12 06:11 AM A surge is good even on a car at stock power level, I've seen them surge at even a 1/3 of a tank on long sweeping corners.I agree with above, people spend heaps on coolers, injectors, tyres etc etc, but don't want a surge tank as its not giving them any extra power etc.Like mick has said you can make 300rwkw on stock cooler and injectors, would he recommend it, not at all! Similar thing with fuel pump. On 12/02/2012 at 8:18 AM, Dillz said: I'm thinkin 1000's to leave the door open to E85 later down the track, If they can be had at a reasonable price that is.May aswell do pump & surge too then Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196072 Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 5m Gender: Male Location: Adelaide Posted 14/02/12 06:12 AM Share Posted 14/02/12 06:12 AM Part No. EFI004P Brand TRIDON Description HOSE CLAMP 7-15mm PART STAINLESS STEEL TRIDON PK10 Unit Each Image Notes EFI004 Extended Tang Micro Clamp 7 - 15 The Tridon EFI part stainless perforated band clamp range provides superior design and proven reliability. Manufactured in Australia, the flexible stainless steel perforated band has an extended tang to cover the perforations and prevent hose damage on soft rubber hoses. Ideally suited for use on fuel and vacuum lines. EFI (Micro Clamp) Band - 301 Stainless Steel (8.0mm wide) Housing - Carbon Steel Zinc Plated Screw - Carbon Steel Zinc Plated (6mm slotted hex head) here is more detail of the EFI clamps as fitted to my surge tank Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196073 Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 5m Gender: Male Location: Adelaide Posted 14/02/12 06:14 AM Share Posted 14/02/12 06:14 AM are these clamps not rated for EFI aplications?The Tridon EFI part stainless perforated band clamp range provides superior design and proven reliability.Manufactured in Australia, the flexible stainless steel perforated band has an extended tang to cover the perforations and prevent hose damage on soft rubber hoses. Ideally suited for use on fuel and vacuum lines. Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196075 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 2m 27d Gender: Male Location: Auckland, New Zealand Posted 14/02/12 06:14 AM Share Posted 14/02/12 06:14 AM Yeah, those are the ones that filled my pump pot with rubber Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196077 Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 5m Gender: Male Location: Adelaide Posted 14/02/12 06:17 AM Share Posted 14/02/12 06:17 AM these are mounted external on the tank, not inside the tank Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196081 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 2m 27d Gender: Male Location: Auckland, New Zealand Posted 14/02/12 06:21 AM Share Posted 14/02/12 06:21 AM Here's my set-upI know it's not perfect size wise but all the hoses are secure where there's pressure. Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196083 Share on other sites More sharing options...
Bigkeels Throbbing Member Donating Members 594 Member For: 16y 2m 9d Gender: Male Location: Victoria Posted 14/02/12 06:24 AM Share Posted 14/02/12 06:24 AM The rubber would of rubbed off the hose and then into pot, yours might be doing the same but the rubber will just fall onto the ground and eventually rub through the hose. Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196088 Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 5m Gender: Male Location: Adelaide Posted 14/02/12 06:31 AM Share Posted 14/02/12 06:31 AM well I have used the correct rated hoses and clamps, it is safe, and that's what matters Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196092 Share on other sites More sharing options...
riptide Member 733 Member For: 14y 2m 27d Gender: Male Location: Auckland, New Zealand Posted 14/02/12 06:43 AM Share Posted 14/02/12 06:43 AM (edited) As long as it's the correct hose for the speedfit fittings it doesn't even need clamps. I think my hose was close to $40 a meter and a hell of a job to push on even using a vice. Must be running ~80psi.Looks like a nice functional set-up anyways Edited 14/02/12 06:44 AM by riptide Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196094 Share on other sites More sharing options...
BAturb Member 521 Member For: 20y 5m Gender: Male Location: Adelaide Posted 14/02/12 08:56 AM Share Posted 14/02/12 08:56 AM (edited) yeh, the hose was bloody dear, and your right it was a hell of a job getting the hose over the fittings, I remember thinking I hope its right coz this hose isnt coming off, and the tank and fittings were pressure tested to 110psi for 5mins in a bucket of water, no bubbles no pressure drop Edited 14/02/12 08:57 AM by BAturb Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/page/17/#findComment-1196169 Share on other sites More sharing options...
