  • Member For: 17y 5m 13d
Yeah it would be listed with the insurance policy. I deal with insurance company's every day, some of the crap the approve and disapprove makes me laugh.
  • Member For: 19y 8m
You don't want a in boot mounted fuel system. You might as well put it under your seat, because your car will smell like it was stolen by a bunch of petrol sniffing thugs..
Everyone I know who's done this in the last has regretted it majorly.
  • Member For: 17y 10m 16d
Nothing wrong with gettin a little buzz on the way to work..
  • Like 2
  • Member For: 18y 10m 22d
True, I've got 2 o44s and a custom 4lt surge tank I've mounted in the spare wheel well, even though I used the speed flow fittings and line there is still the smell getting through, which sux so I don't recommend it to anyone, but in the upside, E85 doesn't smell so there's no smell issues, and o44s run so cold with e85 they are very quiet... It's amazing how loud they get if I have to use 98, takes about 15 mins for them to heat up and buz like mad.
It's good to see fuel pressure has been mentioned, as the pressure is as important as volume.
Here's some simple theory...
Injectors need a certain volume of fuel to flow x amount for the motor to make power, and the volume needs to be controlled by pressure, this pressure is set in the rail, and controlled by the fuel regulator.
IF the stock pump is the only pump in your system, it's the low tank level pick up that greatly reduces the fuel pressure, so less pressure equals lean lean lean afrs, and usually damaged motors if constantly pushed through this lean area.
If your budget does stretch for a surge tank set up, I'd get a fuel pressure gauge , perhaps with a warning light or buzzer, atleast you'll have a warning to tell you to get off the throttle befor you do damage.
Now the stock reg is good, mine is still working fine at 460wkw, but what I've found is that boot mounted pumps supply less pressure at the rail, compared to pump(s) mounted in the enging bay.
This is the reason why slot of guys running 2 044s in the bay have run into idle and cruise issues, as Danny mentioned , super rich mixtures due to the factory reg not being able to flow enough fuel AWAY from the rail.
Myself & CMS have set up quite a few Plaz surge tanks with aeromotive a1000 pumps and haven't had these low rpm fuel mixture issues, so I'd say the 044s , being higher rated (1300 v 1000) push just that little bit too much volume and pressure for the stock reg to flow... Where the A1000 is just enough for the stock reg to flow.
Even though my own car runs 044s in the boot, I much prefer a front mounted surge tank and Aeromotive A1000.
I've got 80s flowing enough E85 for 460wkw, on stock rail pressure, but close to their limits at this pressure... Though we have seen high 500s from 80s but running 95psi rail pressure which is a bit to high for a street car.
  • Member For: 13y 5m 30d
  On 26/01/2012 at 11:45 PM, Bonjaz said:
so headsex in your opinion surge tank and 044 is good enough for high 300s? or you think both intank and surge are needed. It would take alot of WOT to drain a surge tank even with a stock intank pump?
that's something I would also like to know , almost about to order a PW surge . do I need to upgrade the in tank pump as well ?.
I did answer that.
Yes provided the intank pump is in good working order, you have changed both the fuel filter under the car, and the filter sock on the untank pump, it should be fine.
However I'd suggest if your car has high Kay's or many years old now, it may be time to change the intank regardless.
I have seen early Ba ones fail (as Long as 4 years ago)
But is saying this. 99% of the time the intake should be fine, especially of you already has mods and more than 13psi boost.
  • ...JD TUNING ADELAIDE...
  • Member For: 16y 10m 11d
the issue with boot mounted systems is quite simple ...............smell..............there is a way around this but even this pic is done wrong and so is mine
alot of imports have to result to using a boot mounted set up 2 ways of doing it right hard lines and tank (cost is big) or blue/black fittings and e85 capiable teflon hose-not rubber, its amazing how many performance shops say ill do a boot mount for u and it wont smell but then they use red/blue fittings !!! wtf do they have any knowledge about a basic speedflow fitting for christ sake there not just pretty coulours for the hell of it
this is win
this is bigger winner
  • Member For: 18y 10m 15d
And probably for less cost than one of those setups, you could buy a ProcessWest system and not have to modifiy standard hoses at all which means you can go back to totally stock later on if selling the car etc
yeh that's the prob with a decent boot install it will cost more than what we can get for an under car set up, some ppl like the wank factor but then complain when it stinks just throwing some info around
ive used a set of matching ford push pull fittings that go onto the top of my std pump/sender unit works a treat and no damage to the std stuff
Boot would be dangerous too, if you get hit hard from the back...
