bluprinturbo Donating Members 605 Member For: 16y 11m Gender: Male Location: brisbane Posted 14/11/09 09:51 AM Share Posted 14/11/09 09:51 AM im shopping for a final tune on my ba. most want me to fit a surge tank. some dont think its neccessary. whats the truth? Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/ Share on other sites More sharing options...
benjam Member 137 Member For: 20y 7d Location: Sydney NSW Posted 14/11/09 09:31 PM Share Posted 14/11/09 09:31 PM Depends what you want to do with your car. Under half a tank doing circuit racing you'd be running the risk of fuel starvation, which can lean out your air fuel ratio briefly and lead to detonation. Even more serious drag racing or spirited twisty driving around 1/4 of a tank could cause probs. Inside the fuel tank, the fuel gets pushed to one side, away from the pickup due to the G forces. For me I have one just for track days as otherwise I don't push my car hard enough to worry. It means I don't have to refuel after only a couple of ciruit runs. After experiencing the difference I can say it definitely works a treat. Cheers.Ben Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-953990 Share on other sites More sharing options...
bluprinturbo Donating Members 605 Member For: 16y 11m Gender: Male Location: brisbane Posted 14/11/09 09:53 PM Author Share Posted 14/11/09 09:53 PM the car will see ocassional 1/4 mile passes running around 340 rwkws. one tuner is saying that its absolutely mandatory, regardless of fuel level. Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-953993 Share on other sites More sharing options...
PHANTMXR6 It's not a MKI! Member 1,742 Member For: 16y 9m 23d Gender: Male Location: Earth Posted 15/11/09 12:36 AM Share Posted 15/11/09 12:36 AM Either way, it's relatively cheap insurance to have one. Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-954027 Share on other sites More sharing options...
JETURBO ...JD TUNING ADELAIDE... Gold Donating Members 23,708 Member For: 16y 10m 11d Gender: Male Location: Adelaide Posted 15/11/09 12:58 AM Share Posted 15/11/09 12:58 AM yes yes yes ive just found out the importance of such an item ......................cant win when your surging iam also in dyre need of 1 now 2 Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-954034 Share on other sites More sharing options...
RAP1D Member Donating Members 3,739 Member For: 18y 10m 22d Gender: Male Location: Sydney NSW Posted 15/11/09 03:41 AM Share Posted 15/11/09 03:41 AM A good example is my FG.On a full tank it will run around 11.3 afr's on full boost, when the level drops to under a quarter tank, it will go I to the mid 12s and sometimes low 13s.This is all on flat roads, such as freeways just nailing it in 4th.It's accually showing up low fuel presure, from the pump not picking up fuel as well as it does on full tank.I have an AEM wideband O2 metre permenetly set up in the dash so I can monitor AFR's at all times.With the sugetank system now fitted, there's no leaning out at low levels, it sits in the 11s no matter what I do.So surge tanks are not just for track work, they are very good insuance. Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-954085 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 7m 24d Gender: Male Location: NSW Posted 15/11/09 06:38 AM Share Posted 15/11/09 06:38 AM Put one in, it will give you consistancy. Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-954123 Share on other sites More sharing options...
xd turbo Member 58 Member For: 16y 3m 26d Gender: Male Posted 03/01/10 10:04 AM Share Posted 03/01/10 10:04 AM sounds like the done thing to me!! what size pot is required to get the consistancy?I have a 044 pump for the job. will the ebay swirl pot do the job? Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-967784 Share on other sites More sharing options...
d rangd Member 341 Member For: 16y 4m 26d Posted 03/01/10 11:58 AM Share Posted 03/01/10 11:58 AM whats everyones opinion on having 2 044s sucking off a process west surge tank? I know its a relatively small tank but im hoping the walbro intank will keep it full, and its only going to 80lb injectors...?? Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-967830 Share on other sites More sharing options...
Patski Member 23 Member For: 13y 10m 13d Gender: Male Location: Port Macquarie Posted 05/01/12 06:32 PM Share Posted 05/01/12 06:32 PM PW 2lt surge tank and 044 fuel pump comes as a polished unit and uses factory bolts to fit from CV performace for $1100 u say u have the 044 so im sure u can buy it without the pump cheaper Link to comment https://www.fordxr6turbo.com/forum/topic/63575-surge-tanks/#findComment-1177366 Share on other sites More sharing options...
