kyle173 Donating Members 774 Member For: 16y 2m 10d Gender: Male Location: brisbane Posted 28/12/09 01:10 PM Share Posted 28/12/09 01:10 PM wats this exchange zf good for 500rwkw more info please Link to comment Share on other sites More sharing options...
Casey Spencer Member 43 Member For: 15y 2m 30d Gender: Male Location: qld Posted 29/12/09 10:58 AM Share Posted 29/12/09 10:58 AM from what I've heard that's about right and a mob down in sydney builds stall converters for themgood for big turbo's Link to comment Share on other sites More sharing options...
kyle173 Donating Members 774 Member For: 16y 2m 10d Gender: Male Location: brisbane Posted 29/12/09 11:12 AM Share Posted 29/12/09 11:12 AM ok ill be making calls tomoro Link to comment Share on other sites More sharing options...
R_Spec_Matt Donating Members 120 Member For: 15y 7m 11d Gender: Male Location: Sunny Coast QLD Posted 01/01/10 01:36 AM Author Share Posted 01/01/10 01:36 AM A good start is how much money do you want to spend.process west surge tank are cheap and good for the power.60lbs injectors .exchange turbo housings are pretty cheap (labour is the killer).I have a 3.5inch split dump pipe sitting at work, flows as well as a 4inch.battery relocation is easy you could put it in a battery box in the boot, plus you could do it yourselfrapid do a nice four inch intake pipeXtreme Ford Tuning do a exchange 6sp zf good for 500kw+yeah cool mate ill be sein u soon Link to comment Share on other sites More sharing options...
R_Spec_Matt Donating Members 120 Member For: 15y 7m 11d Gender: Male Location: Sunny Coast QLD Posted 04/02/10 10:56 PM Author Share Posted 04/02/10 10:56 PM yeah guys ive been told by a few tune places and on the net that I dont need heavy duty valve springs if im staying under 400rwkws because bf2 has better springs than ba/bf 1, but u guys and some other tune guys say that I need them.... so whats the go, do I get springs if I stayin under 400 rwkws????? or not.....also was told by my tune guy that I dont need a bigger flapper just 10psi actuator and 4" intake housing for turbo and the mods I say ive got/ gettin and I should get round 360-380 rwkws....I aint got much cash left after I got these mods for a tune and I want to get more, so if I dont need springs that would be good so I can get 4" turbo intake housing and a tunemods I already have fitted: process west plenum and intercooler 42lbs injectors 3" dump 3" cat 3" single exhaustmods I just brought: but not yet fitted: 4" intake to turbo and battery airbox 60 lbs injectors front mount surge tank and 044 pump 3.5" split dump with 5" cat into a 3.5" single CES exhaustmods I want to get: 4" turbo intake housing 10 or 12 actuator but using standard flapper heavy duty valvue springs.... yes or no ?????ok guys so let me know is all that good or I need somethings else to keep it on the safe sidecheers guys..... Link to comment Share on other sites More sharing options...
R-SPEC You are a dead set goose Silver Donating Members 3,968 Member For: 19y 1m 12d Gender: Male Location: Melbourne Posted 05/02/10 06:18 AM Share Posted 05/02/10 06:18 AM You'll have major problems controlling boost with no wastegate porting or larger swing valve with a dump and large cat no matter how good your actuator is (by the way, get a 12 or 15psi actuator, not 10!). You've just got to spend the money on it otherwise you'll be forced to keep boost down which will rob you of power output. There's no point doing a 4" housing, spend that money on a wastegate port and keep the turbo standard. The only thing is I've seen people get into trouble with having a split dump and a larger swing valve. As it swings open to bypass gasses it can get jammed by the small dump pipe. You may need to flog it off and get a single 4" dump in future...Also I wouldn't bother with the valve springs. Get boost sorted first, then if things start to shake, get springs Link to comment Share on other sites More sharing options...
